All the settings about reports are listed with short descriptions. Default settings are marked with a dagger (  ).
Asterisks (*)
Settings marked with "*1" are only available for the imageRUNNER 1435iF.
Settings marked with "*2" are only available for the imageRUNNER 1435iF / 1435i.
Settings marked with "*3" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PCL Printer Kit enabled.
Settings marked with "*4" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PS Printer Kit enabled.
Fax TX Result Report*1
Select whether to print a report of a fax transmission result. Select <On> to print the report each time you send a fax, or select <Only When Error Occurs> to print when a sending error occurs.
Fax TX Result Report (imageRUNNER 1435iF Only)
Off
On
Include TX Image
Off
On
E-Mail/File TX Result Report*2
Select whether to print a report of a transmission result sent by e-mail or saved in a file server. Select <On> to print the report each time you send a scanned document, or select <Only When Error Occurs> to print when a sending error occurs.
E-Mail/File TX Result Report (imageRUNNER 1435iF / 1435i Only)
Off
On
Communication Management Report*2
Select whether to print a report of the sending/receiving results log. If you want to print the report automatically, set <Auto Print (40 Transmissions)> to <On> so that the report is printed after every 40 transmissions. If you set <Separate TX/RX> to <On>, the sending results and receiving results are printed separately.
Communication Management Report (imageRUNNER 1435iF / 1435i Only)
Off
On
Separate TX/RX
Off
On
RX Result Report*1
Select whether to print a report of the details for a received fax. Select <On> to print the report each time you receive a fax, or select <Only When Error Occurs> to print when a receiving error occurs.
RX Result Report (imageRUNNER 1435iF Only)
Off
On
Address Book List*2
You can print a list of destinations registered in the Address Book. Lists can be printed separately for the <Coded Dial>, <One-Touch>, and <Group> registration types.
Address Book List (imageRUNNER 1435iF / 1435i Only)
Coded Dial
One-Touch
Group
User Data List
You can print a list of setting items and current settings registered in the machine. This list does not include the setting information for <Network Settings> and <System Management Settings>.
User Data List
System Manager Data List
You can print a list of setting items and current settings registered in the machine. With this list, you can also check the setting information for <Network Settings> and <System Management Settings>.
You can manually print a report of the sending/receiving results log.
Department ID Management Report
You can print a report to check the total number of pages that were copied, printed, and scanned for each Department ID.
IPSec Policy List
You can print a list of policy names and IPSec settings currently registered in the machine.
IPSec Policy List
PCL Font List*3
You can print a list of fonts available in PCL mode.
PCL Font List
PS Font List*4
You can print a list of fonts available in PS mode.
PS Font List
