You can register frequently used destinations in the Address Book and easily select them when needed. You can register up to 300 destinations in the Address Book. Destinations can be searched alphabetically, from lists in the Address Book, or by entering three-digit numbers (coded dial numbers). You can also specify destinations more quickly by using the following features.
Use the Remote UI when registering a file server as the destination for scans.
You can save the Address Book as a file on your computer or a USB memory device (although you cannot use the computer to edit the Address Book). You can also import a saved Address Book from the computer or a USB memory device to the machine.
You can print a list of destinations registered in the Address Book.
If your office has an LDAP server installed, you can register destinations searched from the server in the Address Book. You need to specify the settings for connecting to an LDAP server beforehand.
