Registering Multiple Destinations as a Group
Multiple destinations can be combined into a group. After a group is registered, you can add or delete destinations to or from the group.
1
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_fax18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_scan18.gif)
2
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_address18.gif)
(Address Book).
3
4
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_up18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_down18.gif)
to select <Register New Destination to Address Book>, and press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif)
5
Select <Coded Dial>, and press
Groups can also be registered in the one-touch keys. Select <One-Touch> to register the group in a one-touch key.
6
Select <Group>, and press
If you selected <One-Touch> in step 5, a screen for specifying a one-touch number is displayed. Select the one-touch key number, and press
7
Select <Name>, and press
Registering <Name> is optional. If you register <Name>, the destination can be searched alphabetically.
8
Enter the group name using the numeric keys, select <Apply>, and press
9
Select <Number of Destinations>, and press
10
Select <Add>, and press
11
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_left18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_right18.gif)
to select the tab and
to select the number or address you want to register, and press
12
Repeat steps 10 and 11 until you have registered all of the destinations that you want to register, select <Apply>, and press
13
Select <Apply>, and press
Editing the Content of Registered Groups
After registering destinations, you can change the content of groups such as names, destinations, and coded dial numbers.
1
Press
2
Press
(Address Book).
3
4
Use
to select <Edit Address Book>, and press
5
Select <
![](./images/book_images/b_C514.gif)
6
Select the group you want to edit, and press
7
Select the item you want to edit, press
, and then perform editing.
8
Deleting a Group
1
Press
2
Press
(Address Book).
3
4
Use
to select <Delete From Address Book>, and press
5
Select <
6
Select the group you want to delete, and press
7
Select <Yes>, and press
