      0KCF-09S
      Registering the Address Book from the Remote UI (imageRUNNER 1435iF / 1435i Only)
      You can register or edit the Address Book of the machine by using a computer.
      You can register or edit the Address Book only when you are logging on in System Manager Mode.
      1
      Start the Remote UI and log on in System Manager Mode. Starting the Remote UI
      2
      Click [Address Book].
      3
      Click [Coded Dial].
      You can also register destinations in the one-touch keys. In this case, click [One-Touch] instead of [Coded Dial]. Registering the Address Book (imageRUNNER 1435iF / 1435i Only)
      4
      Click the text link under [Number], [Type], or [Name] for an item named [Not Registered].
      NOTE:
      If the enter PIN page is displayed
      The Address Book is protected by a PIN. Enter the PIN in [PIN:] and click [OK].
      NOTE:
      You can edit a registered destination by clicking the corresponding text link under [Number], [Type], or [Name].
      You can delete a registered destination by clicking [Delete].
      5
      Select the destination type and click [OK].
      6
      Specify required settings and click [OK].
