Registering Destinations in the One-Touch Keys
You can register frequently used destinations in 19 one-touch keys on the operation panel (
Operation Panel).
1
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_fax18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_scan18.gif)
2
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_address18.gif)
(Address Book).
3
4
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_up18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_down18.gif)
to select <Register New Destination to Address Book>, and press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif)
5
Select <One-Touch>, and press
6
Select <Fax> or <E-Mail>, and press
Select <Fax> when registering a fax number, or select <E-Mail> when registering an e-mail address.
The types of destinations that can be selected vary depending on the machine model.
7
Select the one-touch number to register the destination in, and press
The number that you select in this step corresponds to the number of the one-touch key on the operation panel.
Operation Panel
![](./images/book_images/b_C241.gif)
Registering destinations with the LDAP server
![](./images/global_images/1T0002134966/g_ne_toggle_open.gif)
NOTE:
If your office has an LDAP server installed, you can register destinations searched from the server in the Address Book. You need to specify the settings for connecting to an LDAP server beforehand.
Registering LDAP Servers (imageRUNNER 1435iF / 1435i Only)
1
Select <Specify from LDAP Server>, and press ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif) .
2
Search for the destination to register.
According to the content registered in the LDAP server, the user name and the fax number/e-mail address of the specified destination that is registered on the LDAP server will be automatically input.
3
Select a destination, and press ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif) .
4
Proceed to step 12.
8
Select <Name>, and press
Registering <Name> is optional. If you register <Name>, the destination can be searched alphabetically.
9
Enter the name using the numeric keys, select <Apply>, and press
10
Select <Fax Number> or <E-Mail Address>, and press
11
Enter the number or address using the numeric keys, select <Apply>, and press
12
Select <Apply>, and press
Editing the Content of Registered Destinations
After registering destinations, you can change the content of destinations such as numbers, names, types, and one-touch numbers.
1
Press
2
Press
(Address Book).
3
4
Use
to select <Edit Address Book>, and press
5
Select <
![](./images/book_images/b_C465.gif)
6
Select the destination you want to edit, and press
7
Select the item you want to edit, press
, and then perform editing.
8
Deleting a Registered Destination
1
Press
2
Press
(Address Book).
3
4
Use
to select <Delete From Address Book>, and press
5
Select <
6
Select the destination you want to delete, and press
7
Select <Yes>, and press
