Do not turn OFF the machine until the export/import process is complete
It may take a few minutes to complete the process. If the machine is turned OFF during the process, it may result in damage to data or the machine.
Do not operate the machine during the export/import process
Before exporting/importing, check that no operations such as printing documents are currently in progress.
Settings that cannot be exported/imported
The table below shows the limitations when you export setting data from and import it to the same machine (with the same serial number). When you import the data that was exported from other machines of the same model or from other models, less settings, than those listed below, may be imported. For more information, contact your local authorized Canon dealer.
In addition to the settings listed below, some security-sensitive settings or information such as passwords are not exported/imported.
TIPS
Exporting/Importing Using a USB memory device
You can use a USB memory device to export or import data.
Importing data from other models
You can export/import the Address Book and menu options data to/from other models that are compatible with this machine. For more information, contact your local authorized Canon dealer.
This machine supports some plug-ins that can be added to imageWARE Enterprise Management Console. This software enables you to efficiently manage the information that is stored in multiple machines, giving more flexibility such as when you share the Address Book data among different models.
