Registering Scanned File Destinations in the Address Book
This section describes how to register the e-mail and file server destination using the Remote UI. File server destinations can only be registered via Remote UI.
You can change the settings only when you have logged on in System Manager Mode.
1
2
Click [Address Book].
NOTE:
If the enter PIN page is displayed
The Address Book is protected by a PIN. Enter the PIN in [PIN:] and click [OK].
3
Click [Coded Dial].
4
Click the text link under [Number], [Type], or [Name] for an item named "Not Registered."
NOTE:
You can edit a registered destination by clicking the corresponding text link under [Number], [Type], or [Name].
You can delete a registered destination by clicking [Delete].
5
Select [E-Mail] or [File] in [Destination Type to Register] and click [OK].
6
Specify the required settings and click [OK].
Registering an e-mail address
[Name]
Enter the name you want to register.
[E-Mail Address:]
Enter the e-mail address of the destination.
Registering a file server address
[Name]
[Protocol:]
Select [Windows (SMB)] or [FTP].
[Host Name:]
Specify the host name or the IP address of the destination.
[Folder Path:]
Enter the folder path of the file server.
[User Name:] / [Password:]
If access restrictions are set to the folder, the user name and password is needed. If you need a password, select the check box and enter the password.
LINKS
