Booklet Scanning
This mode enables you to scan originals in such a way that, when printing the scanned data, the output paper can be made into a booklet. Specify the Booklet mode when printing the scanned data. (See "Booklet Mode" and "Perfect Binding.")
Press (Main Menu) → [Scan and Store].
Select the desired Mail Box → press [Scan].
Press [Options] → [Booklet Scan].
4.
Select the desired booklet scanning size.
If you place a two-sided original, press [2-Sided Original] → select the type of two-sided original → press [OK].
[Book Type]:
The front and back sides of the original have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the original have the opposite top-bottom orientation.
To specify the original size, press [Change] for <Original Size> → select the size → press [OK].
To change the booklet layout size, press [Change] for <Layout Size> → select the layout size → press [OK].
You cannot select [2-Sided Original] if STMTR is the selected original size.
The machine automatically selects the zoom ratio depending on the selected layout size.
5.
Press [OK] → [Close].
Originals must all be the same size.
Make sure to place originals with a vertical (portrait) orientation vertically. If these originals are placed horizontally, the even numbered pages will be printed upside down.
» Scan and Store » Booklet Scanning
0S9Y-0R7
