(Main Menu) → [Scan and Store].
Prevents dark background color from being copied, but light areas on the original may not be copied either.
You may not be able to completely prevent dark background color from being copied, but light areas on the original are always copied.
If you press [Adjust All Colors] on the color adjustment screen for [Adjust Each Color], the screen returns to the Adjust All Colors screen.
If you adjust the background density by pressing [Adjust] for <Background Density>, the [Auto] setting is canceled. Similarly, if you press [Auto] while making manual adjustments in [Adjust], your adjustments are canceled. The machine automatically adjusts the density to match the background.
