Hard Disk Holder
Holds the hard disk. To store the hard disk, place it in the hard disk holder.
Front Cover
Open this cover to set/remove the hard disk holder.
PWR Indicator
Lights when power is supplied to the HDD.
4.
Operation Indicators
When the HDD is operating, the ACT indicator lights. In the event of an error, the ERR indicator lights.
One Removable HDD Kit is attached to the left side of the top of the marking engine by default. To expand on this by installing the Canon HDD Data Encryption & Mirroring Kit, contact your local authorized Canon dealer.
If the message <E602-0001> appears on the touch panel display when the machine starts, a hard disk may not be inserted in the Removable HDD Kit.Turn OFF the main power of the machine, check that the PWR indicator on the attached part of the hard disk is not lit, and then check theRemovable HDD Kit. If the error message still appears after you correctly set the hard disk, contact your local authorized Canon dealer.
