The High Capacity Stacker-H1 enables you to continuously stack a large amount of paper. Up to two stackers can be attached to this machine.
The High Capacity Stacker-H1 is equipped with two trays. You can remove output paper on one tray while outputting paper to the other tray.
For more information on the High Capacity Stacker-H1, see the manual available at the following URL:
http://global.oce.com/support/.
When the High Capacity Stacker-H1 is attached to this machine, the stack capacity is 3000 sheets (80 g/m2 (20 lb bond)). The maximum stack height is 302 mm (11 1/8"). The maximum stack capacity differs, depending on the content of the print or sheet type.
