Upper Tray
You can load paper you want to use as a cover, sheet insertion, or job separator, etc.
Lower Tray
Tray Cover
Lift to load paper in the lower tray.
4.
Slide Guides
Adjust the slide guides to match the width of the original.
5.
Front Cover
Open this cover to remove jammed paper. (See "Document Insertion Unit-N1 (Optional).")
Paper which has been rolled or curled must be straightened out before placing it into the Document Insertion Unit-N1. (See "Caution for Paper Curl.")
Do not place the following types of paper into the Document Insertion Unit-N1. Doing so may cause a paper jam.
Insertion sheets with tears
Severely curled or wrinkled paper
Clipped or stapled insertion sheets
Transparencies or other highly transparent insertion sheets
Labels
Some types of paper cannot be used with the Document Insertion Unit-N1. For more information, contact your local authorized Canon dealer.
For information on the available paper, see "Available Paper Stock."
How to Place the Cover Sheet/Original
Staple Settings/Output
Result |
Document Insertion Unit-N1*1
Feeder
Platen Glass
Corner: Upper Left
Double: Left
![]() LTR
Corner: Lower Left
Double: Left
![]() 11" x 17" 11" x 17"
LGL
Corner: Upper Right
Double: Right
LGL
Corner: Lower Left
Double: Left ![]() LTR
Corner: Upper Right
Double: Right
![]() LTR
Corner: Upper Left
Double: Left
LGL |
Corner: Upper Right
Double: Right
![]() LTR
Corner: Upper Left
![]() 11" x 17", LGL
Corner: Lower Right
Corner: Upper Left
![]() LTR
Corner: Lower Right
![]() LTR
Corner: Upper Right
Double: Right
LGL |
Saddle Stitch
For instructions on loading paper into the Document Insertion Unit-N1, see "Loading Paper into the Document Insertion Unit-N1 (Optional)."
