If the machine is in the Sleep mode (the touch panel is not displayed, and only
(Energy Saver) is lit), you may be unable to open the POD Deck-D1/Secondary POD Deck-D1. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the POD Deck-D1/Secondary POD Deck-D1. |
For information on the available paper, see "Available Paper Stock."
POD Deck-D1 + Secondary POD Deck-D1
POD Deck-D1
Front Cover (Buffer Pass)
Open this cover to remove jammed paper.
Escape Tray
Outputs any subsequent paper when a paper jam occurs. Minimizes the paper jam removal procedures.
Main Power Switch of the POD Deck-D1
Press to the "I" side to turn ON the POD Deck-D1.
4.
Main Power Switch of the Secondary POD Deck-D1
Press to the "I" side to turn ON the Secondary POD Deck-D1 .
5.
Tab Feeding Attachment-E1
Use the Tab Feeding Attachment-E1 to load the tab paper into the paper deck.
6.
Open Button
Press to open the paper deck when you need to load paper or check for a paper jam.
The paper supply indicator enables you to check the amount of paper remaining in the paper deck. |
7.
Horizontal Pass Cover
8.
Front Right Cover
9.
Paper Deck
Up to 1,000 sheets of paper (20 lb bond (80 g/m2)) each can be loaded into the upper and middle decks, and up to 2,000 sheets of paper (20 lb bond (80 g/m2)) can be loaded into the lower deck.
10.
Tandem Pass Cover
