If the machine is in the Sleep mode (the touch panel is not displayed, and only
(Energy Saver) is lit), you may be unable to open the POD Deck Lite-C1. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the POD Deck Lite-C1. |
For information on the available paper, see "Available Paper Stock."
Release Button
Press to move the POD Deck Lite-C1 away from the main unit when you want to detach either of them from the machine.
Open Button
Press to open the POD Deck Lite-C1 when you need to load paper or check for a paper jam.
Paper Deck
Up to 3,500 sheets of paper (20 lb bond (80 g/m2)) can be loaded. |
