e-Manual
Top
Site map
Help
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products
Software
Settings/Registration
Paper Type Management
Adjustment for Image Quality and Finishing (Calibration)
Maintenance
Problem Solving
Copy
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Quick Menu
Status Monitor/Cancel
Remote UI
Security
How to Use This Manual
Expand All
Collapse All
Category Top
System Configuration
Optional Equipment
Sample System Configurations
System Options
Optional Products Required for Each Function
Upright Control Panel-F1
Duplex Color Image Reader Unit-K1
Tab Feeding Attachment-E1
LONG SHEET TRAY-A1
POD Deck Lite-C1
POD Deck-D1/Secondary POD Deck-D1
Finisher-AN1/Saddle Finisher-AN2/Puncher Unit-BS1/Puncher Unit-BT1
Document Insertion Unit-N1
Paper Folding Unit-J1
High Capacity Stacker-H1
ADF Access Handle
Removable HDD Kit/HDD Data Encryption & Mirroring Kit
Setting/Removing the Hard Disk Holder
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Optional Products
Software
Maintenance
Problem Solving
Copy
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Quick Menu
Remote UI
Security
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Optional Products
ADF Access Handle
ADF Access Handle
0S9Y-049
The ADF Access Handle helps you to close the feeder. This is an optional product for the feeder.
Parts and Their Functions
ADF Access Handle
Closes the feeder.
Back to Top
