If the machine is in the Sleep mode (the touch panel is not displayed, and only
For information on the available paper, see "Available Paper Stock."
To detect when multiple papers are fed with the Multi-drawer Paper Deck-B1, the Paper Deck Double Feeding Detection Kit-A1 is required.
Front Cover (Buffer Pass)
Open this cover to remove jammed paper. (See "Front Cover of the Multi-drawer Paper Deck-B1 (Optional).")
Open Button
Press to open the paper deck when you need to load paper or check for a paper jam.
Paper Deck
Up to 2,000 sheets of paper (20 lb bond (80 g/m2)) each can be loaded into the upper, middle, and lower decks
