If the machine is in the Sleep mode (the touch panel is not displayed, and only
For information on the available paper, see "Available Paper Stock."
Release Button
Press to move the POD Deck Lite-B1 away from the main unit when you want to detach either of them from the machine.
Open Button
Press to open the POD Deck Lite-B1 when you need to load paper or check for a paper jam.
Paper Deck
Up to 3,500 sheets of paper (20 lb bond (80 g/m2)) can be loaded. |
4.
POD Deck Lite Attachment Kit-A1
The POD Deck Lite Attachment Kit-A1 is required to attach the POD Deck Lite-B1 to the machine. Open the POD Deck Lite Attachment Kit-A1 when you need to check for a paper jam. (See "Clearing Paper Jams.")
