e-Manual
Top
Site map
Help
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products
Software
Settings/Registration
Paper Type Management
Adjustment for Image Quality and Finishing (Calibration)
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
How to Use This Manual
Expand All
Collapse All
Category Top
System Configuration
Optional Equipment
Sample System Configurations
System Options
Optional Products Required for Each Function
Upright Control Panel-D1
Duplex Color Image Reader Unit-H1
Tab Feeding Attachment-F1
Envelope Feeder Attachment-F1 (for Paper Drawers)
Stack Bypass-B1
Stack Bypass Alignment Tray-C1
POD Deck Lite-B1
Multi-drawer Paper Deck-B1
USB Device Port-A3
Multimedia Reader/Writer-A3
Printer Cover-F1
Finisher-AM1/Saddle Finisher-AM2/Puncher Unit-BS1/Puncher Unit-BT1
Staple Finisher-T1/Booklet Finisher-T1/External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1
Professional Puncher Integration Unit-C1
Document Insertion Unit-M1
Paper Folding Unit-F1
Output Tray-A1
High Capacity Stacker-G1
Copy Card Reader-F1
ADF Access Handle
Removable HDD Kit
Setting/Removing the Hard Disk Holder
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Optional Products
Software
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Optional Products
USB Device Port-A3
USB Device Port-A3
0L3X-03K
If you want to use the Multimedia Reader/Writer-A3, you must attach the USB Device Port-A3 to the machine.
Back to Top
