e-ManualTopSite mapHelp
Top » Optional Products » System Configuration » Optional Equipment
Optional Equipment
0L3X-034
Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1
The Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1 trim the fore edge and top/bottom of saddle stitched copies for neat output.
Saddle Finisher-AM2
The Saddle Finisher-AM2 is equipped with the following features: Collate, Group, Staple (Corner, Double, and Saddle Stitch), and Saddle Fold.
Staple-P1
The Staple-P1 can be attached to the Saddle Finisher-AM2 for saddle stitching.
4.
Paper Folding Unit-F1
If the Paper Folding Unit-F1 is attached to the Finisher-AM1 or Saddle Finisher-AM2, the paper can be folded in 5 different ways (Z-Fold, Half Fold, C-Fold, Accordion Z-Fold, and Double Parallel Fold).
5.
High Capacity Stacker-G1
The High Capacity Stacker-G1 enables you to continuously stack a large amount of paper.
6.
Perfect Binder-D1
The Perfect Binder-D1 is equipped with the following features: book binding, gluing, trimming, and stacking.
7.
Professional Puncher Integration Unit-C1
The Professional Puncher Integration Unit-C1 reverses the paper punched by the Professional Puncher-B1 to prevent a paper jam.
8.
The Professional Puncher-B1 punches several types of hole. For more information on the Professional Puncher-B1, see the instruction manual of the Professional Puncher-B1.
9.
Document Insertion Unit-M1
If the Document Insertion Unit-M1 is attached, a different type of paper from the body of the document can be inserted for a cover or insert.
10.
Duplex Color Image Reader Unit-H1
Originals placed in the feeder are automatically fed sheet by sheet to the platen glass for scanning. You can scan documents such as books, thick originals, thin originals, and transparencies on the platen glass of the Duplex Color Image Reader Unit-H1.
11.
Copy Card Reader-F1
The Copy Card Reader-F1 enables Department ID Management to be performed through the use of cards.
12.
Upright Control Panel-D1
The Upright Control Panel-D1 includes the keys, touch panel display, and indicators required for operating the machine. (See "Control Panel Parts and Functions.")
13.
Multi-drawer Paper Deck-B1
If the Multi-drawer Paper Deck-B1 is attached, it can provide three additional paper sources. Up to 2,000 sheets of paper (20 lb bond (80 g/m2)) each can be loaded into the upper, middle, and lower decks of the Multi-drawer Paper Deck-B1.
14.
POD Deck Lite-B1
If the POD Deck Lite-B1 is attached, it can provide an additional paper source. The POD Deck Lite-B1 holds up to 3,500 sheets of paper (20 lb bond (80 g/m2)).
15.
Envelope Feeder Attachment-G1
Attach the Envelope Feeder Attachment-G1 to load envelopes into the POD Deck Lite-B1.
16.
POD Deck Lite Attachment Kit-A1
The POD Deck Lite Attachment Kit-A1 is required to attach the POD Deck Lite-B1 to the machine.
17.
Printer Cover-F1
Instead of the Duplex Color Image Reader Unit-H1, you can attach the Printer Cover-F1.
18.
Output Tray-A1
The Output Tray-A1 is equipped with the following features: Collate, Group, and Rotate 90 Degrees.
19.
Stack Bypass-B1
Use the Stack Bypass-B1 to feed paper manually.
20.
Stack Bypass Alignment Tray-C1
The Stack Bypass Alignment Tray-C1 aligns paper placed on the Stack Bypass-B1.
21.
Envelope Feeder Attachment-F1
Attach the Envelope Feeder Attachment-F1 to load envelopes into the paper drawers of this machine.
22.
Tab Feeding Attachment-F1
Attach the Tab Feeding Attachment-F1 to load tab paper into the paper drawers of this machine.
23.
Auto Gradation Sensor-A1
The Auto Gradation Sensor-A1 enables you to perform Auto Adjust Gradation without using a scanning unit.
24.
Storage Box for Glass Cleaning Cloth
Store the glass cleaning cloth in this box.
25.
External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1
The External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1 is equipped with the Hole Punch mode. The External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1 can be attached only if the Staple Finisher-T1 or Booklet Finisher-T1 is attached.
26.
Booklet Finisher-T1
The Booklet Finisher-T1 is equipped with the following features: Collate, Group, and Staple (Corner, Double, and Saddle Stitch), and Saddle Fold.
27.
Staple Cartridge-D2/Staple Cartridge-D3
The Staple Cartridge-D2/Staple Cartridge-D3 can be attached to the Booklet Finisher-T1 for saddle stitching.
28.
Staple-J1
The Staple-J1 can be attached to the Staple Finisher-T1 or Booklet Finisher-T1 for stapling (Corner and Double).
29.
Staple Finisher-T1
The Staple Finisher-T1 is equipped with the following features: Collate, Group, and Staple (Corner and Double).
30.
Finisher-AM1
The Finisher-AM1 is equipped with the following features: Collate, Group, and Staple (Corner and Double).
31.
Staple-N1
The Staple-N1 can be attached to the Finisher-AM1 or Saddle Finisher-AM2 for stapling (Corner and Double).
32.
Puncher Unit-BS1/Puncher Unit-BT1
The Puncher Unit-BS1/Puncher Unit-BT1 is equipped with the Hole Punch mode. The Puncher Unit-BS1/Puncher Unit-BT1 can be attached only if the Finisher-AM1 or Saddle Finisher-AM2 is attached.
33.
Booklet Trimmer-D1
The Booklet Trimmer-D1 trims the fore edge of saddle stitched copies for neat output.
