Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Selecting the Code for Document Scan Lock (TL Code/QR Code)
Document Scan Lock Settings (TL Code)
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode (TL Code)
Adjusting the TL Code
Document Scan Lock Settings (QR Code)
Specifying the Document Scan Lock Operational Settings (QR Code)
Setting the Document Scan Lock Mode (QR Code)
Setting the Document Scan Lock Mode and Secure Watermark (QR Code)
Adjusting the QR Code Print Position
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
ACCESS MANAGEMENT SYSTEM
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Device Management » Specifying Device Information Delivery Settings » Setting Manual Delivery
0CYL-231
You can set to manually deliver device information.
Press [Management Settings] → [Device Management] → [Device Information Delivery Settings].
Press [Manual Delivery] for <Transmitting Settings>.
4.
Specify each setting → press [Next].
Press [On] for an item to deliver that data.
If you press [On] for <Settings/Registration Value>, set <Network Settings>. You can press [Include] → [OK] to deliver the network settings.
5.
Select the destination → press [Start Manual Delivery].
If you want to cancel the delivery, press [Cancel].
When delivery is complete, confirm the delivery results displayed in the 'Status' column on the Manual Delivery screen.
Even if you press [Cancel], delivery will not be canceled for machines to which information has already been delivered. Delivery to the next selected machine will be canceled.
6.
Press [OK] → [OK].
When delivering device information, the following machines will not update their information:
Machines which are processing a send job
Machines importing or exporting data via the Remote UI
The client machine which is receiving device information from another host machine will not update the address book.
The client machine which is performing a print job will not update the printer settings.
