Specifying Department ID Management
0CYL-1YY
Using Department ID Management
Press
(Settings/Registration).
Press [Management Settings] → [User Management] → [Department ID Management].
Press [On] → [OK].
If you do not want to use Department ID Management, press [Off].
Registering the Department ID, PIN, and Page Limit
Press
Press [On] → [Register PIN].
4.
Press [Register].
5.
Enter the Department ID and PIN using
(numeric keys).
Press [Dept. ID] → enter the Department ID.
Press [PIN].
Press [PIN] → enter the PIN.
Press [Confirm] → enter the same number to confirm the PIN → press [OK].
Even if you enter fewer than seven digits, zeros are added to the start of the number, and a seven digit number is set. However, the zeros at the start of the number can be omitted when logging in. For example, even if you enter <2>, <02>, or <002>, the PIN is set as <0000002>. However, you can log in by entering <2>, <02>, or <002>.
You cannot register a System Manager ID or System PIN comprised of only zeros, such as <0> or <00>.
You can clear incorrect values by pressing  (Clear).
If you do not set a PIN, you can use the machine by entering only the Department ID.
6.
Press [Turn Limits On/Off and Set Page Limits].
7.
Set the page limits.
The number of sides refers to the number of printed sides. Therefore, the number of sides of a two-sided print is counted as two. The page limit refers to the maximum number of printed sides.
Press [On] under the desired function(s).
Total Print Limit is the sum of Copy Limit and Print Limit.
Color Scan Limit and Black Scan Limit are not included in the Total Print Limit.
Press
(Page Limit) next to [On]/[Off] of the desired function(s).
Enter the page limit using
(numeric keys).
The machine stops sending a fax if the Scan Limit is reached while faxing a document either from memory or directly to the recipient.
The machine stops scanning if the Scan Limit is reached while the machine is scanning originals that are being fed from the feeder. (Those originals that were scanned before the limit is reached are not added to the scan count.)
You can set the page limit from 0 to 999,999 pages. Once a page limit is reached, copying, scanning, or printing is not possible. When the page limit is reached, the following screen appears.
When copying:
When scanning an original to be sent:
When printing:
Press [OK] → [OK].
8.
Press [OK] → [OK].
If the Copy Card Reader-F1 is attached and a page limit is set, the Count Left (the page limit minus the Page Count) appears on the Basic Features screen for each function. For information on the Copy Card Reader-F1, see
"Copy Card Reader-F1."
You can use Department ID Management for limiting functions except Copy and Print function. The login screen appears according to the specified settings as described below.
If all limit function settings are set to 'On':
The login screen appears as the default screen displayed after startup/restoration. Enter the Department ID and PIN in order to use each function.
If some of the limit function settings are set to 'Off':
The screen specified in "Default Screen after Startup/Restoration" appears as the default screen displayed after startup/restoration. The login screen appears when you select functions which are limited to use. Enter the Department ID and PIN in order to use the functions.
Press
Display the PIN registration screen.
When the Copy Card Reader-F1 is not attached:
Press [Limit Functions].
When the Copy Card Reader-F1 is attached:
Press [Register PIN].
4.
Press [On] for the functions (other than the Copy/Print function) you want to limit using Department ID Management.
You can limit the following functions:
[Store/Access Files, Fax/I-Fax Inbox]:
[Send/Fax]:
[Other]:
If you want to limit the Copy and Print functions, press [Off] for all the functions.
<Send/Fax> is displayed only if the fax board is installed. If the fax board is not installed, <Send> is displayed.
If [Department ID Management] is set to [On], functions other than described above and MEAP applications operate as explained below regardless of limit function settings.
The following function and MEAP application are limited to use.
The following function is not limited to use.
5.
Press [OK] → [OK] → [OK].
If you are managing the machine using control cards and there is a function with its limit set to 'Off' in [Limit Functions], the Main Menu screen appears when the machine starts. In this case, perform the procedure from step 1 without inserting a control card.
The Count Left only appears for functions with their limit set to 'On'.
On the Copy Basic Features screen and the Print Settings screen, the two items with the lowest Count Left appear. However, if the Total Print Limit is the lowest, only the Total Print Limit appears.
Changing the PIN and Page Limit
You can change the PIN and page limit settings that you have registered.
Press
4.
Press
to display the department whose PIN you want to change → select the department → press [Edit].
By holding down
, you can scroll quickly and continuously backward or forward through the available Department ID pages. When the desired page is displayed, release the keys. Continuous scrolling is useful when a large number of Department IDs are registered.
5.
Enter the desired PIN using
(numeric keys).
Press [PIN].
Press [PIN] → enter the new PIN.
You cannot change the Department ID.
6.
Press [Turn Limits On/Off and Set Page Limits] → change the page limit.
7.
Press [OK] → [OK].
8.
Press [OK] → [OK].
You can delete a Department ID that you have registered.
Press
4.
Press
to display the department you want to delete → select the department → press [Delete].
By holding down  or  , you can scroll quickly and continuously backward or forward through the available Department ID pages. When the desired page is displayed, release the keys. Continuous scrolling is useful when a large number of Department IDs are registered.
5.
Press [Yes].
6.
Press [OK] → [OK].
If Department ID Management is activated through the Copy Card Reader-F1, you cannot register/delete Department IDs.
