Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Selecting the Code for Document Scan Lock (TL Code/QR Code)
Document Scan Lock Settings (TL Code)
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode (TL Code)
Adjusting the TL Code
Document Scan Lock Settings (QR Code)
Specifying the Document Scan Lock Operational Settings (QR Code)
Setting the Document Scan Lock Mode (QR Code)
Setting the Document Scan Lock Mode and Secure Watermark (QR Code)
Adjusting the QR Code Print Position
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
ACCESS MANAGEMENT SYSTEM
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage » Mail Box Settings » Specifying Settings for All Mail Boxes
0CYL-22E
You can specify settings for the time until files in all of the mail boxes are deleted automatically, as well as whether to print upon storing from the printer driver.
Press [Function Settings] → [Store/Access Files] → [Mail Box Settings].
Press [Settings for All Mail Boxes] → specify each setting → press [OK].
<Time Until File Auto Delete>:
Press or to set the time that has to elapse before files are automatically deleted.
<Print When Storing from Printer Driver>:
You can select whether to print a file when it is sent from a computer and stored in a mail box. To print a file when it is stored in a mail box, select [On].
Regardless of the PIN settings for individual mail boxes, the settings specified in [Settings for All Mail Boxes] are given priority, even if the settings for [Time Until File Auto Delete] and [Print upon Storing from Printer Driver] in [Set/Register Mail Boxes] have been specified for individual mail boxes. However, if settings for individual mail boxes are changed after specifying settings in [Settings for All Mail Boxes], the settings for each individual mail box are given priority. (See "Mail Box Settings.")
