Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Selecting the Code for Document Scan Lock (TL Code/QR Code)
Document Scan Lock Settings (TL Code)
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode (TL Code)
Adjusting the TL Code
Document Scan Lock Settings (QR Code)
Specifying the Document Scan Lock Operational Settings (QR Code)
Setting the Document Scan Lock Mode (QR Code)
Setting the Document Scan Lock Mode and Secure Watermark (QR Code)
Adjusting the QR Code Print Position
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
ACCESS MANAGEMENT SYSTEM
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Specifying Management Settings for the Hard Disk » Initializing All Data/Settings
0CYL-22L
If this mode is performed, the following data stored in the machine are completely erased. It is not normally necessary to use this mode, but it is useful to erase personal or confidential information when returning or disposing of the machine.
Data stored in mail boxes/Advanced Box
Data stored in Fax/I-Fax Inbox (Confidential Fax Inbox/Memory RX Inbox)
Address data stored in the Address Book
Scan settings registered for the Sending function
[Favorite Settings] registered for the Copy, Store/Access Files, and Send functions
MEAP applications and license files
Data saved from MEAP applications
The password for the SMS (Service Management Service) login service of MEAP
(If you changed the password, it returns to the default password.)
User authentication information registered in the Local Device Authentication system of SSO-H (Single Sign-On H)
Unsent documents (reserved documents and documents set with the Delayed Send mode)
Job history
Settings/Registration settings
Forms registered for the Superimpose Image mode
Registered forwarding settings
Key Pair and Server Certificate registered in [Certificate Settings] in [Device Management] in [Management Settings] (Settings/Registration)
Before initiating the Initialize All Data/Settings mode, make sure that the data you are erasing is completely unnecessary. Note that Canon will not be liable for any damages resulting from the loss of data.
If the Copy Card Reader-F1 is attached to the machine, and does not operate properly after initializing the data, contact your local authorized Canon dealer.
To prevent other users from accidentally erasing all the data on the hard disk, it is recommended to register a System Manager ID and System PIN so that only the System Manager can perform this procedure.
Confirm that there are no current jobs being processed before using the Initialize All Data/Settings mode.
Backup or export any necessary data before erasing the data in the machine. You can backup or export the following data:
Data you can backup using the Remote UI
Mail box settings, stored files in the mail box, stored files in the Advanced Box, and registered forms for Superimpose Image (For information on backing up data, see "Backing Up Stored Data.")
Data you can export using the Remote UI
(Depending on the MEAP application, you may be able to backup this data. For more information, see the manual for the MEAP application you are using.)
User information authenticated by [User Access Control for the Advanced Box]
(For information on exporting user information, see "Exporting User Information.")
License files for MEAP applications
(For information on downloading license files, see "Managing Application Licenses.")
(For information on exporting authentication information, see "Registering/Editing User Data for Local Device Authentication.")
Settings which can be sent using the Device Information Delivery mode
(Can only be backed up if you have another machine with the Device Information Delivery mode. It is not necessary to back up this data if you want to use the data already registered in the other machine. For more information on the Device Information Delivery mode, see "Specifying Device Information Delivery Settings.")
(Depending on the MEAP application, you may be able to back up this data. For more information, see the manual for the MEAP application you are using.)
Press [Management Settings] → [Data Management] → [Initialize All Data/Settings].
Select the deletion mode → press [Start].
Details of each item are shown below:
[Once with 0 (Null) Data]:
Overwrite the data once with 0 (null) data.
[Once with Random Data]:
Overwrite the data once with random data.
[3 Times with Random Data]:
Overwrite the data three times with random data.
[9 Times with Random Data]:
Overwrite the data nine times with random data.
[DoD Standard]:
Overwrite the data three times. The first time is with a fixed value, the second time with a complement of the fixed value, and the third time is with random data.
It may take more than 30 minutes to initialize the hard disk.
By executing the Initialize All Data/Settings mode, the machine will automatically restart.
After the machine restarts, Initialize All Data/Settings Report will be printed automatically.
If there are any current jobs being processed, they will be canceled, and then erased.
You cannot access the machine while the hard disk is being initialized.
The Initialize All Data/Settings mode does not delete any data the machine has stored on a server or computer.
For information on Initialize All Data/Settings Report, see "Initialize All Data/Settings Report."
