Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Selecting the Code for Document Scan Lock (TL Code/QR Code)
Document Scan Lock Settings (TL Code)
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode (TL Code)
Adjusting the TL Code
Document Scan Lock Settings (QR Code)
Specifying the Document Scan Lock Operational Settings (QR Code)
Setting the Document Scan Lock Mode (QR Code)
Setting the Document Scan Lock Mode and Secure Watermark (QR Code)
Adjusting the QR Code Print Position
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
ACCESS MANAGEMENT SYSTEM
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage » Forced Secure Watermark/Document Scan Lock » Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
0CYL-21S
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Forced Secure Watermark enables you to set the machine to always print the specified hidden watermark on prints and copies.
Press [Function Settings] → [Common] → [Print Settings].
Press [Secure Watermark Settings].
If the Document Scan Lock Kit is activated, press [Secure Watermark/Document Scan Lock].
4.
Press [Forced Secure Watermark].
If the Document Scan Lock Kit is activated, press [Forced Secure Watermark/Doc. Scan Lock].
5.
Press [Set] for the function (<Copy>/<Access Stored Files>/<Printer>) to set the Forced Secure Watermark mode.
If the Document Scan Lock Kit is activated, press [Force Secure Watermark] for the function (<Copy>/<Access Stored Files>/<Printer>) to set the Forced Secure Watermark mode.
6.
Select the type of secure watermark to embed (Watermark, Date, Copy Set Numbering, Serial Number, or ID/User Name).
To select Watermark:
To select Date:
To select Copy Set Numbering:
To select Serial Number:
To select ID/User Name:
Press [Watermark] → press the <Watermark Type> drop-down list → select the watermark type.
If you select [Custom] from the <Watermark Type> drop-down list, press [Enter] → enter the desired text → press [OK].
For instructions on entering characters, see "Entering Characters from the Touch Panel Display." If you have registered characters in [Register Characters for Page No./Watermark] in [Function Settings] (Settings/Registration), you can select the characters from the list.
To select Date:
Press [Date] → press the <Date Format> drop-down list → select the format of the date.
Press [Copy Set Numbering] → set the starting number.
Press [Serial Number].
The Serial Number, which appears at the bottom left of the screen when you press (Counter Check) on the control panel, is printed.
Press [ID/User Name].
If a login service has been set, the Department ID and user name of the user who is currently logged in to the machine are printed.
The watermark "CONFIDENTIAL" is printed if a login service is not set.
7.
Set the background pattern and size.
To print a pattern on the background of copy, select the background pattern from the Background Pattern drop-down list.
You can select [36.0 pt], [54.0 pt], or [72.0 pt] for the size of the text.
To change the print orientation for characters, press [Print Vertically].
To use white letters on a colored background, press [White Letters on Colored Bkg.].
8.
Press [OK].
If you set the Printer Driver Secure Watermark mode, you can select whether to set the Secure Watermark function for each print job from printer drivers.
4.
Press [Printer Driver Secure Watermark].
If the Document Scan Lock Kit is activated, press [Printer Driver Watermark/Doc. Scan Lock].
5.
Press [Set].
If the Document Scan Lock Kit is activated, press [Driver Secure Watermark].
6.
To select Date:
To select Date:
The Serial Number, which appears at the bottom left of the screen when you press (Counter Check)on the control panel, is printed.
7.
8.
Press [OK].
If [Printer Driver Secure Watermark] and [Forced Secure Watermark] are set for a printer at the same time, Forced Secure Watermark is given priority.
If you want to use the Secure Watermark function for each job from the printer driver, on the [Printing Preferences] dialog box, click the [Finishing] tab → [Advanced Settings] → select [On] for [Secure Printing Function of Devices]. For more information, see the on-line help for the printer driver.
