Category
Top » Scan and Store » Booklet Scanning
Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Scan and Store Operations
Storing Scanned Originals in a Mail Box
Storing Scanned Originals in the Advanced Box
Storing Originals on the Network
Storing Originals into Memory Media
Canceling a Job While Scanning
Storing Originals While Printing
Favorite Settings
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Switching the Color Mode
Setting the Resolution
Changing the Zoom Ratio
Setting the File Format
Trace and Smooth
Compact PDF Files
Searchable PDF Files
PDF Files with a Digital Signature
Encrypting PDF Files
Applying a Policy
Storing a Reader Extensions Compatible PDF
Selecting the Original Type
Adjusting Density Manually
Adjusting Background Density
2-Sided Original
Book → 2 Pages
Booklet Scanning
N on 1
Erase Frame
Different Size Originals
Job Build
Inverting Images (Nega/Posi)
Adjusting the Image Sharpness
Combination of Functions Chart
Collapse all|Expand all
Booklet Scanning
This mode enables you to scan originals in such a way that, when printing the scanned data, the output paper can be made into a booklet. Specify the Booklet mode when printing the scanned data. (See "Booklet Mode.")
This mode is only available for storing files in a mail box.
Press [Scan and Store] → [Mail Box].
Select the desired Mail Box → press [Scan].
Press [Options] → [Booklet Scan].
4.
Select the desired booklet scanning size.
If you place a two-sided original, press [2-Sided Original] → select the type of two-sided original → press [OK].
[Book Type]:
The front and back sides of the original have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the original have opposite top-bottom orientations.
To specify the original size, press [Change] for <Original Size> → select the size → press [OK].
To change the booklet layout size, press [Change] for <Layout Size> → select the paper size → press [OK].
The machine automatically selects the zoom ratio depending on the selected paper size.
5.
Press [OK] → [Close].
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
Originals must all be the same size.
Make sure to place originals with a vertical (portrait) orientation vertically. If these originals are placed horizontally, the even numbered pages will be printed upside down.
