If the machine is used as a network printer, you can store data in the machine from a computer via the network printer.
For instructions on placing originals, see "Placing Originals."
to scroll to the desired mail box.
(numeric keys) → press [OK].|
If you make a mistake when entering the mail box number using the numeric keys, press [Cancel] → enter the correct mail box number.
You cannot use the following characters in a file name: \ / : , * ? " < > |
You cannot use a . (period) or space for the first or last character of the file name.
The full pathname, including folders and the file name, must not exceed 256 characters in length.
If you create a file without manually assigning it a name, the machine automatically assigns the file a name. This name is created using the year, month, day, and time the file was created.
For example, if a file is created at 1:35 PM, 41 seconds, on 01.15.11, its name will be <20110115133541>. If you enter a file name that already exists, (1) to (9) is added to the file name. Example: a(1).pdf
(Start).
(Start) to scan each original. Your original is scanned.
To cancel scanning, press [Stop] or
(Stop). |
If you want to scan a color image, it is necessary to expand the memory capacity of the machine with the Additional Memory Type A (512MB).
You can scan and store up to 999 pages at one time. If two-sided originals are scanned using the feeder, you can store up to 1,000 pages. Once the maximum number of originals you can scan is reached, a message asking whether to store appears.
To check whether the file was stored correctly, press
(Status Monitor/Cancel) → [Store] → [Log]. If the result is displayed as "NG," press [Details] to check the error code. For more information on the causes and remedies for each error code, see "List of Error Codes without Messages." |
