1
[Up]
Press to return to the upper level.
2
[Check Media Information]
Press to check the details of memory media.
3
![]() Press to remove the memory media.
1
![]() You can specify the following settings:
Register to Quick Menu (See "Quick Menu.")
2
[Name]
Press to sort the files by name, in ascending or descending order.
[Date/Time] Press to sort the files by date/time, in ascending or descending order. |
3
[Folder Operations]
Press to display the menu for editing the folders in the memory media.
4
[Display Image]
Press to view the contents of the selected file.
5
[Edit File]
Press to add a file or delete the selected file.
6
[Scan]
Your original is scanned and stored in the memory media. |
7
[Details]
Press to check the details of the selected file. |
8
[Clear Selection]
Press to cancel the selection of a file. |
9
[Up]
10
[Update]
Press to update the contents of the memory media.
1
[Add Files (Scan and Store)]
Press to add a file.
2
[Delete]
Press to delete files stored in the memory media. You can select and delete up to 32 files at a time.
If you want to use the following resolution settings to scan a color image, it is necessary to expand the memory capacity of the machine with the Additional Memory Type A (512MB).
200 x 400 dpi
400 x 400 dpi
600 x 600 dpi
1
Register/Edit Favorite Settings
Changing the Default Settings
2
[Direct]
Press to scan your document in the same size as your original. |
3
[Copy Ratio]
Press to reduce or enlarge the scanning size of the original.
4
[Scan Size]
Press to set the size of the original that you are going to scan.
5
[File Format]
Press to select the file format for the files to store.
6
[Favorite Settings]
Press to recall scan settings or register frequently used settings in the Favorite Settings.
7
[Back to Default Set.]
Press to cancel all settings. (The machine restores the default settings for Scan and Store.)
8
[Options]
Press to specify useful scan settings, such as scanning different size originals together or dividing originals into multiple batches.
9
[File Name]
Press to assign the file a name.
10
[Density]
Press to adjust the density for scanning. |
11
[Original Type]
Press to select the type of original (text only, photo only, or both text and photo) you are going to scan.
12
[2-Sided Original]
Press if you are scanning a two-sided original.
13
[Select Color]
Press to select the color for scanning.
14
[Resolution]
Press to select the resolution for scanning.
You cannot store documents in the memory media if there is no free space available.
For instructions on checking detailed information for memory media, see "Checking the Detailed Information for Memory Media."
For information on the types of icons displayed for memory media, see "Types of Advanced Box/Network/Memory Media Icons."
For instructions on arranging folders, checking detailed information for the file, and editing/deleting files, see "Access Stored Files."
