Category
Top » Scan and Store » Favorite Settings
Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Scan and Store Operations
Storing Scanned Originals in a Mail Box
Storing Scanned Originals in the Advanced Box
Storing Originals on the Network
Storing Originals into Memory Media
Canceling a Job While Scanning
Storing Originals While Printing
Favorite Settings
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Switching the Color Mode
Setting the Resolution
Changing the Zoom Ratio
Setting the File Format
Trace and Smooth
Compact PDF Files
Searchable PDF Files
PDF Files with a Digital Signature
Encrypting PDF Files
Applying a Policy
Storing a Reader Extensions Compatible PDF
Selecting the Original Type
Adjusting Density Manually
Adjusting Background Density
2-Sided Original
Book → 2 Pages
Booklet Scanning
N on 1
Erase Frame
Different Size Originals
Job Build
Inverting Images (Nega/Posi)
Adjusting the Image Sharpness
Combination of Functions Chart
Collapse all|Expand all
Favorite Settings
You can register up to nine frequently used setting combinations. You can also set easy to remember names for each.
This feature is useful for storing frequently used scan, print, and copy settings.
As an example, the procedure for selecting a mail box as the storage location is explained in this section.
The settings stored in [Favorite Settings] are not deleted, even if the main power is turned OFF.
You can also store/edit favorite settings by pressing → [Register/Edit Favorite Settings].
