The Forced Document Scan Lock/Printer Driver Document Scan Lock mode enables you to adjust the size, density, etc. of dots embedded in the document.
This setting can be specified when the Document Scan Lock function is available for use. For information on the optional products required to use the Document Scan Lock function, see
"Optional Products Required for Each Function."
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Print Settings].
Press [Document Scan Lock Settings].
If the Secure Watermark is activated, press [Secure Watermark/Document Scan Lock].
4.
Press [Adjust TL Code] → adjust the dots.
If you want to adjust the size of the dots:
Press [-] or [+] to set the size of the dots.
The appropriate dot size differs according to the usage environment, the content of the original, or the content of the file. We recommend that you check documents embedded with a TL code to see whether you can correctly analyze the tracking information and whether the TL code restricts copying.
Any value from one to seven may be used for the size of the dots.
If you want to adjust the density of the dots:
Press [Standard] or [Rough].
If there are many illustrations or images in the original or file, we recommend that you select [Standard].
5.
Press [OK] → [OK].
To restore the default settings, press [Initialize] → [Yes].
