Category
Top » Flow of Settings » Using the Machine as a Scanner
Category Top
Operations Required Prior to Using the Machine
Logging In to the Machine as an Administrator
Sending E-Mail/I-Faxes
Sending Data to a File Server
Opening the Advanced Box of the Machine Externally on the Network
Setting Up an Advanced Box on the Same Network
Using Memory Media
Directly Sending Faxes from the Machine
Sending and Receiving Faxes via the Remote Fax Server
Sending Faxes from a Computer via the Machine
Printing from a Computer
Managing the Machine from a Computer
Connecting the Machine to an External Network and Registering/Updating Software
Registering/Updating Software Without Connecting the Machine to an External Network
Collapse all|Expand all
The following operations and settings are required to use the machine as a scanner.
For information on the system requirements for installing the scanner driver, see "System Requirements."
1. Connect the machine to the network.
2. Set the machine to use the TCP/IP network.
3. Install the software for specifying scanner settings (Network ScanGear) into the computer connected to the machine.
To Practical Workflows
Adding the Scanned Image via Network Scanner onto a Document
