Category
Top » Flow of Settings » Sending Data to a File Server
Category Top
Operations Required Prior to Using the Machine
Logging In to the Machine as an Administrator
Sending E-Mail/I-Faxes
Opening the Advanced Box of the Machine Externally on the Network
Setting Up an Advanced Box on the Same Network
Using Memory Media
Directly Sending Faxes from the Machine
Sending and Receiving Faxes via the Remote Fax Server
Sending Faxes from a Computer via the Machine
Printing from a Computer
Using the Machine as a Scanner
Managing the Machine from a Computer
Connecting the Machine to an External Network and Registering/Updating Software
Registering/Updating Software Without Connecting the Machine to an External Network
Collapse all|Expand all
The following operations and settings are required to send data to a file server with the machine.
For information on the system requirements for using this function, see "Sending Data."
The file servers you can use differ depending on the network you are using. For information on the file servers you can use, refer to the following, according to the network you are using.
1. Connect the machine to the network.
2. Set the machine for the type of network you are using.
For a TCP/IP network:
For an SMB/CIFS network
3. Set up the file server.
For an FTP server
For a WebDAV server
For a Windows shared folder/Samba shared folder
To Practical Workflows
Scanning the Original and Sending to a Computer
