Category
Top » Scanner » Before Using the Network Scanner
Category Top
System Requirements
Installation
Selecting the Scanner
Scanning Fundamentals
Switching the Scanner Online and Offline
Scanning from the Platen Glass
Scanning from the Feeder
Viewing the Online Help
Scanning Originals with Correct Orientation
Scanning Different Sized Originals Together
Specifying the Scanning Area
Department ID Management
Setting a Department ID and PIN Beforehand
Entering the Department ID and PIN When You Scan
Questions & Answers
Collapse all|Expand all
To scan and enable the computer to receive data from the scanner, you need to install a scanner driver (Network ScanGear/Color Network ScanGear) on the computer. Also, you need to select a scanner with the ScanGear Tool.
The scanner driver is installed from the same User Software CD-ROM as the printer driver.
