Category
Top » Flow of Settings » Sending Faxes from a Computer via the Machine
Category Top
Operations Required Prior to Using the Machine
Logging In to the Machine as an Administrator
Sending E-Mail/I-Faxes
Sending Data to a File Server
Opening the Advanced Box of the Machine Externally on the Network
Setting Up an Advanced Box on the Same Network
Using Memory Media
Directly Sending Faxes from the Machine
Sending and Receiving Faxes via the Remote Fax Server
Printing from a Computer
Using the Machine as a Scanner
Managing the Machine from a Computer
Connecting the Machine to an External Network and Registering/Updating Software
Registering/Updating Software Without Connecting the Machine to an External Network
Collapse all|Expand all
The following operations and settings are required to send faxes from a computer via the machine.
For information on the system requirements for using this function, see "Printing or Sending a Fax from a Computer."
For information on the system requirements for installing the fax driver, see the following:
System Requirements for Windows
1. Connect the machine to a computer.
To connect via a network
To connect via USB*
*Proceed to step 3 after connecting the machine.
2. Set the machine for the type of network you are using.
For a TCP/IP network
For a NetWare network
For an SMB/CIFS network
For an AppleTalk network
3. Install the fax driver in the computer to use.
Sending Faxes from a Computer (Windows)
Sending Faxes from a Computer (Mac)
4. Specify the settings required for sending faxes.
