Category
Top » Flow of Settings » Operations Required Prior to Using the Machine
Category Top
Logging In to the Machine as an Administrator
Sending E-Mail/I-Faxes
Sending Data to a File Server
Opening the Advanced Box of the Machine Externally on the Network
Setting Up an Advanced Box on the Same Network
Using Memory Media
Directly Sending Faxes from the Machine
Sending and Receiving Faxes via the Remote Fax Server
Sending Faxes from a Computer via the Machine
Printing from a Computer
Using the Machine as a Scanner
Managing the Machine from a Computer
Connecting the Machine to an External Network and Registering/Updating Software
Registering/Updating Software Without Connecting the Machine to an External Network
Collapse all|Expand all
This section describes the flow of operations and settings required prior to using the machine, for the functions you will use.
Confirm the Following Settings
Some functions of the machine require optional products and operations/settings.
Also, if you want to use functions that require license registration, see "Adding New Functions." See the flowcharts in this category for functions that require operations or settings.
For information on optional products, see "Optional Products/Software."
For information on the system requirements for using the following functions, see "Optional Equipment and System Requirements."
Printing or Sending a Fax from a Computer for Printing (USB/network)
Using E-Mail/I-Fax for Scanning and sending (via e-mail/I-fax)
Sending Data for Scanning and sending (to a file server)
Function
Optional Product Required
License Registration
Operations Required
Copy
None
None
Scanning and Storing/
Files/Accessing Stored Files
Mail Box
None*1
None
Advanced Box/Network
None*1*2
Memory Media*3
None*1*2
Scanning and Sending Files
E-Mail/I-Fax
None*1
Sending Files to File Servers
None*1
Fax
Sending Files from the Machine
Fax Board
Not required
Receiving Files on the Machine
Fax Board
Not required
Sending Files from a Computer via the Machine
Fax Board
Not required
Sending and Receiving Files via the Remote Fax Server
Remote Fax Kit
Required
Print
UFR II Print
None
PCL Print
PCL Printer Kit
Required
PS Print
PS Printer Kit
Required
Barcode Print
Barcode
Printing
Kit
Required
Direct Print
None*4
Remote UI
None
MEAP Management Function (SMS)
None
Registering/Updating Software (Distribution)
None
Registering/Updating Software (Manual)
None
Scanning
None
*1 To scan color images with the following resolutions, the Additional Memory Type A (512MB) is required.
200 × 400 dpi
400 × 400 dpi
600 × 600 dpi
*2 To print PDF files, the PS Printer Kit or Direct Print Kit (for PDF/XPS) is required. (Each optional product requires license registration.)
*3 The default setting for displaying Memory Media is [Off]. To use memory media, press [Display Settings] in [Preferences] (Settings/Registration) → set <Memory Media> in [Store Location Display Settings] to [On].
*4 To print PDF files from a computer, Direct Print Kit (for PDF/XPS) or PS Printer Kit is required. (Each optional product requires license registration.)
To print XPS files from a computer, Direct Print Kit (for PDF/XPS) is required. (The optional product requires license registration.)
