Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Printing the TX Report
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Setting Your Own E-Mail Address as the Destination
0R9W-0YY
When you want to send to yourself, you can specify the e-mail address of the login user as the destination.
Press [Scan and Send] → [Send to Myself].
If you set the Local Device Authentication system of User Authentication as the login service, your e-mail address as registered in the Local Device Authentication system of User Authentication is set as the destination.
If you set server authentication in the "Server Authentication + Local Device Authentication" system of User Authentication, the e-mail address set for the user that logged in with server authentication or the e-mail address registered in imageRUNNER ADVANCE Tracker is set.
If you set to perform authentication by User Authentication, appropriate operations for each authentication are needed. If you are performing user authentication using the User Authentication login service, see "Logging In to the Machine Using the Control Panel."
[Send to Myself] appears only if you register a user's e-mail address when you are using authentication by User Authentication.
A user with the required privileges can limit general users so that they may only use [Send to Myself] when sending e-mail. (See "Setting Limited Destination for Sending E-Mail" and "Setting Administrators.")
