Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Printing the TX Report
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Setting the File Format
0R9W-10X
You can set the file format to use when scanning originals.
Press [Scan and Send] → specify the destination → press the file format button.
Select a file format for the image to send.
[JPEG]:
Sends the file in the JPEG format, if you select a color mode other than Black-and-White.
[TIFF]:
Sends the file in the TIFF format, if you select Black-and-White for the color mode.
[PDF]:
Sends the file in the PDF file format, regardless of the color mode. You can also specify additional settings.
[XPS]:
Sends the file in the XPS file format, regardless of the color mode. You can also specify additional settings.
[OOXML]:
Sends the file in the Office Open XML (pptx/docx) format only if you select the Full Color mode or the Grayscale mode for the color mode.
If you send the file stored in the Memory RX Inbox, you cannot select OOXML as the file format.
If you select [JPEG]:
If you select [TIFF], [PDF], [XPS], or [OOXML]:
Press [OK].
If you select [JPEG], [Divide into Pages] is set to 'On'.
Specify whether or not to divide your files into separate pages → press [OK].
If you want to separate multiple images and send them as separate files, set [Divide into Pages] to 'On'. If you want to send the images as a single file, set the setting to 'Off'.
You can select additional settings if you send in the PDF, XPS or OOXML format. Refer to the following for instructions on setting each type of PDF, XPS, or OOXML:
[Trace & Smooth]: Trace and Smooth
[OCR (Text Searchable)]: Searchable PDF/OOXML
[Apply Policy]: Applying a Policy
