Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Printing the TX Report
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Specifying a Destination by Entering a File Server » Specifying a File Server Using the Keyboard
0R9W-0YR
You can specify a file server as the destination directly from the keyboard displayed on the touch panel display. Press [Host Name], [Folder Path], [User Name], or [Password] to specify the file server settings.
Press [Scan and Send] → [New Destination].
Press [File].
Select the desired server protocol from the drop-down list.
You can use the server protocols below.
Confirm the system environment of the destination before sending.
System Requirements:
Protocol
System Requirements
Application
FTP
Solaris 10
Mac OS X 10.7/10.8/10.9
Red Hat Linux 9
Windows Server 2003 R2 SP2
Internet Information Services 6.0
Windows Vista SP2
Windows Server 2008 SP2
Internet Information Services 7.0
Windows Server 2008 R2 SP2
Windows 7
Internet Information Services 7.5
Windows 8
Windows Server 2012
Internet Information Services 8.0
Windows 8.1
Windows Server 2012 R2
Internet Information Services 8.5
Windows(SMB)
Windows Vista SP2
Windows 7
Windows 8
Windows 8.1
Windows Server 2012
Red Hat Linux 9
Mac OS X 10.6
Samba 2.2/3.0
WebDAV
Solaris 10
Red Hat Linux 9
Mac OS X Server 10.7/10.8/10.9
Apache 2.0
Windows Vista SP2
Windows 7
Windows 8
Windows Server 2012
Windows 8.1
If you are using WebDAV and connect to the Internet using a proxy server, the proxy server must support IPv6.
4.
Specify each setting.
Item
Description
Host Name
A host name is a name assigned to a host computer that provides services on the network. In this entry box, enter the name of the file server on the network as the destination of the send job.
If you select [FTP] or [WebDAV] as the server protocol, you can also specify a port number after the host name address by entering a colon (:) followed by the port number.
Example: 192.168.100.50:21000
When sending to an IPv6 host, specify the following settings for [Host Name]:
[IPv6 Address]:<Port Number>
Example: [5aed:90a0:bc05:01d2:568a:2fc0:0001:12ee]:21000
Make sure to enter the same port number for the Host Name as the one specified for the FTP server or WebDAV server to which you are sending your documents.
Folder Path
A folder path is a series of characters that signify the location of the folder. Specify a folder in the file server as the destination of the send job.
User Name
The login user name for the file server.
To enter the user name only:
Example: user_name
To enter the user name and the domain name:
Example: domain_name\user_name
To enter a UPN (User Principal Name):
Example: user_name@domain_name.com
Password
The login password for the file server.
To add another destination, press [Next Destination] → repeat steps 3 to 4.
If you select [Windows (SMB)] as the server protocol, you can specify the file server by pressing [Browse]. For instructions on using the Browse key, see "Specifying a File Server Using the Browse Key (Windows (SMB))."
If you select [Windows (SMB)] as the server protocol, you can specify the file server by pressing [Search Host]. For instructions on using the Search Host key, see "Specifying a File Server Using the Search Host Key (Windows (SMB))."
If you select [WebDAV] as the server protocol in [Host Name], the HTTP protocol is used if you specify 'HTTP://' as the scheme at the start of the host name. The SSL + HTTP (HTTPS) protocol is used if you specify 'HTTPS://' as the scheme at the start of the host name. Specifying 'HTTPS://' as the scheme enables SSL communications between the server and the machine. You can confirm whether the SSL server certificate is valid when sending with WebDAV by setting [Confirm SSL Certificate for WebDAV TX] to 'On'.
You can only use UPN (User Principal Name) if you are sending to a computer belonging to a domain operated with Active Directory.
When sending to a file server on the Internet using WebDAV, proxy server settings may be required, depending on the environment of the destination. (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
5.
Press [OK].
