Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Printing the TX Report
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Favorite Settings
Favorite Settings
0R9W-102
If you frequently send documents with the same document settings to the same destination, it is convenient to store these settings in a favorite button. Then, when you need to specify the destination, all you have to do is select the favorite button containing your stored document settings and the desired destination, and send your document.
To use this feature, you must first register the desired document settings and destinations in a favorite settings button. For instructions on registering destinations and settings in a favorite settings button, see "Registering/Editing Favorite Settings."
Press [Scan and Send] → [Favorite Settings].
Select the desired Favorite Settings button.
Press [Yes].
You can manually change the settings recalled from the selected button before you send your documents.
If multiple destinations are stored in the selected button, the destinations may not be listed in the order in which they were set.
The destinations registered in the one-touch buttons stored in the favorite buttons of the client machine are not updated even if those registered in the one-touch buttons of a server machine are updated. Confirm if the destination is updated when you cannot send to the registered destinations.
