Basic Operations for Scanning Documents
This section describes the basic operations for scanning documents.
1
Place the document.
Placing Documents
2
Press <Scan and Send> on the Main Menu.
<Main Menu> Screen
3
Specify the destination on the Scan Basic Features screen.
Scan Basic Features Screen
Specifying Destinations from the Address Book
Specifying Destinations from One-Touch Buttons
Entering Destinations Manually
Specifying Destinations in the LDAP Server
Specifying Your Own E-Mail Address
Specifying Personal Folder
Specifying Destinations from the Address Book of a Mobile Device
NOTE:
To specify e-mail destinations as Cc or Bcc, press <Cc Bcc>
<Cc> or <Bcc>
<Specify Destinations> before specifying destinations.
To specify multiple destinations, press <Specify Destinations> and specify an additional destination.
To delete a destination, select the destination you want to delete, and press <Delete Dest.>.
1
Press <Address Book>.
2
Select the destination and press <OK>.
If an access number is set when the destination is registered, press <Access No.> and enter the access number using the numeric keys. The corresponding destination is displayed in the Address Book.
To use the Remote Address Book, press <To Remote Address Book>. When <Change Address Book> is displayed, press <Change Address Book>
<Remote>.
Destination type buttons
Pressing
, and
displays e-mail, file server, and group destinations, respectively.
Drop-down list for selection of Address Book types
When you are logged in to the machine with personal authentication management, selecting <Personal Address List> displays your personal Address Book. You can also display the dedicated Address Book for the user group (user group address book) that includes yourself.
<Search by Name>
Enables you to search the destination by the name you are entering.
Search buttons by first letter
Enables you to narrow down a search by the first letter of the destination name.
Back to Top
1
Press <One-Touch>.
2
Select the desired one-touch button and press <OK>.
To specify the destination using a one-touch button number (one-touch number), press
and enter the number for the desired one-touch button.
Back to Top
You can specify destinations manually that are not registered in the Address Book or one-touch buttons.
1
Press <New Destination> and select <E-Mail> or <File>.
NOTE:
Selecting <Store in Mail Box> enables you to save scanned documents in the Mail Box of the machine.
Selecting <I-Fax> enables you to send scanned documents as a fax via the Internet.
2
Specify the destination and press <OK>.
NOTE:
If you select <File> in step 1, specify the settings such as the IP address of a file server and the path of the save location folder. For details about the setting items, consult your network administrator.
Back to Top
You can search and specify destinations registered in the LDAP server.
1
2
Press <To LDAP Server>.
<LDAP Server>.
If the network password input screen is displayed, enter the user name and password and press <OK>.
3
When searching destinations in the LDAP server, press <Search by Conditions> or <Search by Name>.
To display all the destinations in the LDAP server, proceed to step 4.
When searching by conditions
Press <Search by Conditions>, specify the search conditions on the screen, and press <Start Searching>.
Search categories
Select a criterion to search for destinations from name, e-mail address, organization name, and organization unit (department name, etc).
Search conditions
Select a search condition such as a destination name that contains "John" and a department name that begins with "Development."
Search characters
Press <Set> and enter search characters for the search condition.
NOTE:
To search with multiple conditions
You can search destinations with multiple conditions. Specify the first search condition, press <Add Search Condition>, and then select <or> or <and> for the next condition.
To change conditions and search again
Press <Delete> to delete the specified contents, and specify the conditions again.
When searching by name
Press <Search by Name>
enter the text to search
press <OK>.
NOTE:
You can specify attributes used when performing "Search by Name" for a destination from the LDAP server.
Configuring to "Search by Name" for LDAP Searches
4
Back to Top
You can specify the e-mail address of the user who is logged in to the machine with personal authentication management.
1
Press <Send to Myself>.
The e-mail address of the user who is logged in to the machine is specified as the destination.
Back to Top
You can specify the personal folder of the user who is logged in to the machine with personal authentication management.
1
Specify <Personal Folder>.
The personal folder of the user who is logged in to the machine is specified as destination.
Back to Top
You can specify a destination from the address book of a mobile device.
To use this function, you must install the "Canon PRINT Business" application to your mobile device.
Utilizing the Machine through Applications
1
Press <Mobile Portal>.
2
Connect to the mobile device.
Linking with Mobile Devices
3
Send the address from the mobile device to the machine.
For detailed information on operations using the mobile device, see "Canon PRINT Business Help."
NOTE:
You can send information including the subject, message body, and file name from the mobile device to the machine.
Specifying E-Mail Settings
Back to Top
4
Specify the scan settings as necessary.
Selecting a File Format
Selecting Resolution
Specifying the Scanning Size of Documents
Selecting Color Scan/Black & White Scan
Scanning Both Sides of Documents
Enlarging or Reducing
Scanned documents are converted into electronic files such as PDF. Select the file format according to your purposes and environment of use.
1
Press the setting button for file format.
2
Select the file format.
Depending on the file format you are selecting, you can specify the additional functions including <Compact>.
When creating files by pages
To scan a multiple-page document as separate files by pages, not as a single file, press <Divide into Pages>  enter "1"  press <OK>. If you select <JPEG>, a file for each page is created automatically.
TIPS
Installing an option can expand functions for scanning to create files. System Options
Back to Top
To scan a document clearly, increase the resolution. To reduce the file size, decrease the resolution.
1
Press the setting button for resolution.
2
Select the resolution and press <OK>.
Depending on the file format you are selecting, the resolution that you can select is limited.
Back to Top
If you are scanning free size/highly transparent documents, or the edge of documents is missing when scanning, you need to manually specify the scanning size.
1
Press the setting button for scanning size.
2
Select the scanning size and press <OK>.
When scanning a free size document
Place the document in the feeder and select <Free Size>.
When specifying the values of scanning size
Place the document on the platen glass, select <Custom>, and enter the height and width of the document.
When scanning a long document
Place the document in the feeder and select <Long Original>.
To register the scanning size
If you frequently specify the scanning size with the same values, register the size in <Custom>  <Register Size> to quickly recall the setting for convenience.
Back to Top
You can specify color when scanning documents.
1
Press the setting button for color.
2
Select the color and press <OK>.
Depending on the file format you are selecting, the setting item that you can select is limited..
<Auto (Color/Gray)>
Determines automatically what color is used for scanning according to the color of a document. For example, color pages are scanned in color, and monochrome pages are scanned in grayscale (monochrome gradation).
<Auto (Color/B&W)>
Determines automatically what color is used for scanning according to the color of a document. For example, colored pages are scanned in color, and monochrome pages are scanned in black and white. Select this mode when text is faint with <Auto (Color/Gray)>, or when the document mainly consists of text.
<Full Color>
Scans in color regardless of a document's color. Select this mode when color is not recognized properly such as when the document has color close to black, has faint color or a smaller colored area.
<Black & White>
Scans in black and white regardless of a document's color. This mode is automatically set for the TIFF file format.
<Grayscale>
Scans in grayscale regardless of a document's color. This mode uses different shades of color, such as black, dark gray, gray, light gray, and white, making color look more natural and beautiful compared with <Black & White>.
Back to Top
The machine can automatically scan both the front and back sides of a document.
Place the document in the feeder. For landscape-oriented documents, place them horizontally.
1
Press <2-Sided Original>.
2
Select <Book Type> or <Calendar Type> and press <OK>.
Select <Book Type> for originals whose images on the front and back sides face the same direction, or <Calendar Type> for originals whose images on the front and back sides face in opposite directions.
Back to Top
You can enlarge or reduce standard size documents to other standard sizes when scanning.
Enlarging or Reducing in Standard Paper Sizes
You can enlarge or reduce by specifying magnification (%).
Enlarging or Reducing by Specifying Magnification
You can enlarge or reduce to automatically fit the paper size selected.
Enlarging and Reducing to Fit the Finished Paper Size
1
Press <Options>
<Copy Ratio>.
2
To enlarge, select magnification from
, to reduce, select magnification from
and press <OK>.
3
Press <Close>.
Back to Top
1
Press <Options>
<Copy Ratio>.
2
Specify magnification and press <OK>.
3
Press <Close>.
Back to Top
1
Press <Options>
<Copy Ratio>.
2
Press <Auto>, specify the finished size, and then press <OK>.
Depending on the resolution you are selecting, you cannot specify the finished size.
3
Press <Close>.
Back to Top
5
Press
Documents are scanned and sending/saving starts.
To cancel scanning, press <Cancel> or
<Yes>.
When <Press the [Start] key to scan the next original.> is displayed
Place the next document to scan and press
. When scanning all of the documents is complete, press <Start Sending> to send/save the file.
To cancel sending/saving, press <To Status Mntr./Cncl.>
select a document
<Cancel>
<Yes>.
To check the statuses for sent/saved documents
On the <Status Monitor/Cancel> screen, you can check the statuses for sent/saved documents. This screen enables you to send/save documents again or cancel sending/saving after checking the statuses. Checking Status and Log for Scanned Documents
To print the report for the results of sending/saving
On the Scan Basic Features screen, pressing <Options>  <TX Report> enables you to set to automatically print the report listing the results of sending/saving.
File name
When a file is sent/saved, its file name is automatically set based on the following format. You can change the setting so that a different name can be assigned. Setting a File Name
When sending by e-mail "Job numbers (four digits)_page numbers (three digits).file extension name" format, such as "1042_001.jpg"
When saving in a file server "The year, month, day, hour, minute, and second the file is saved (14 digits).file extension name" format, such as "20151030133541.jpg"
E-mail subject
When multiple sheets are fed
Scanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Scan Basic Features screen  <Detect Feeder Multi Sheet Fd.> each time you send/save a document to disable the setting, or set <Set Detection of Feeder Multi. Sheet Feed as Default> to <Off> ( <Set Detection of Feeder Multi. Sheet Feed as Default>).
TIPS
Determining the top and bottom of the document
You can set the orientation of the document before scanning so that its top and bottom are positioned correctly when the sent/saved file is displayed on a computer.
When placing a LTR size original, press <Options> on the Scan Basic Features screen  <Original Content Orientation>  <Original Content Orientation>  <OK>.
When placing large-sized originals such as LGL size, press <Options> on the Scan Basic Features screen  <Original Content Orientation>  select <Top at Far Edge> or <Top at Side Edge> according to the orientation of the original  press <OK>.
Specifying multiple destinations including faxes
Setting <Enable Fax in Scan and Send Function> to <On> enables you to specify fax destinations from the Scan Basic Features screen ( <Display Fax Function>). This setting is useful for specifying multiple destinations including faxes, such as when saving a copy of a sent fax in a file server.
Checking scanned documents before sending/saving
Registering frequently used settings
LINKS
