Utilizing the Machine through Applications
Print and scan by using applications from a mobile device connected to the machine. Various applications including those exclusive to Canon are supported. Use properly in accordance with your device, the application, and the situation.
Printing/Scanning via Canon PRINT Business
You can print from mobile devices that support iOS/Android, and place and scan originals with the machine, then send to a mobile device. When printing, it is not necessary to perform operations on the machine. To perform scanning, start Canon PRINT Business on the mobile device after pressing <Scan for Mobile> in <Main Menu> on the machine. You can also change settings of jobs stored in the machine from a mobile device, and specify an e-mail address registered in a mobile device as a <Scan and Send> destination. For more information on supported operating systems, detailed setting methods, and operations, see the Canon website.
Printing with Canon Print Service
You can easily print from the menu of applications that support the Android print subsystem. For more information on supported operating systems and detailed settings and procedures, see the Canon website (http://www.canon.com/).
Printing by Mopria™
The machine also supports Mopria™. Using Mopria™ enables you to print from mobile devices that support Android using common operations and settings, even if manufacturers and models differ. For example, if you are using printers supporting Mopria™ made by multiple manufacturers or a printer supporting Mopria™ that is located in a place you are visiting, you can print without installing an application exclusive for each manufacturer or model. For more information on supporting models or operation environments, see http://www.mopria.org.
Confirming Mopria™settings
Printing with Google Cloud Print
You can use applications and services which support Google Cloud Print to print from a computer or mobile device without using a printer driver. Using Google Cloud Print
Printing from Windows Phone (Windows 10 Mobile or Later)
You can print documents from Windows Phone. It is not necessary to download an application or use a driver. To use this feature, make sure that <Use WSD Printing>, <Use WSD Browsing>, and <Multicast Discovery Settings> are enabled. <WSD Settings>
13WR-09F
