<Display Settings>
This section describes the display settings for the touch panel display.
<Default Screen after Startup/Restoration>
<Preferences>
<Display Settings>
You can set the default screen displayed at startup/restoration.
Depending on the authentication method specified in personal authentication management, the Log In screen may be displayed before the screen set in <Default Screen after Startup/Restoration> is displayed.
<Default Screen (Status Monitor/Cancel)>
<Preferences>
<Display Settings>
You can change the screen that is displayed when you press
<Copy Screen Display Settings>
<Preferences>
<Display Settings>
You can specify the screen that appears when you press <Copy>.
Changing the Settings Quickly (Express Copy Screen)
<Display Fax Function>
<Preferences>
<Display Settings>
You can set the machine to display the Fax function on the Main Menu screen. If you choose to display the Fax function, you can also select whether to display <Fax> in <Scan and Send>. Doing so enables you to send to fax, e-mail, and I-fax destinations at the same time.
<Store Location Display Settings>
<Preferences>
<Display Settings>
You can change the destinations that are displayed when you press <Scan and Store> or <Access Stored Files>.
<Switch Language/Keyboard>
<Preferences>
<Display Settings>
You can select the language/keyboard displayed on the touch panel display.
Some messages may not be displayed properly in the selected language. In this case, restart the machine. Some messages may not change even after the machine is restarted.
If Server Authentication + Local Device Authentication are set using personal authentication management, and there is a difference between the language set on the machine and the one set in Active Directory, the sender's full name will not appear in e-mail messages sent to the recipient.
<Display Switch Language/Keyboard Button>
<Preferences>
<Display Settings>
You can display the button that enables you to switch the language and keyboard layout. The button is displayed in the lower-right of the screen.
<Use Keyboard Shift Lock Feature>
<Preferences>
<Display Settings>
If you press <Offset> on the keyboard screen, you can enter an uppercase letter. You can specify the shift lock settings for entering uppercase letters continuously or for entering text which begins with an uppercase letter.
<Display Remaining Paper Message>
<Preferences>
<Display Settings>
You can set to display a message indicating that the remaining paper loaded in a paper source is low.
<No. of Copies/Job Duration Status>
<Preferences>
<Display Settings>
The number of copies specified and the approximate time before the current job completes are displayed on the bottom line of the touch panel display.
The accuracy of the approximate times that appear on the bottom line of the touch panel display may vary, depending on the status of the machine.
The approximate time does not appear when the wait time is less than one minute.
<Paper Type Selection Screen Priority>
<Preferences>
<Display Settings>
You can set whether to prioritize the simple (<Simple>) or detailed (<Detailed>) setting screen when you display the screen to select the paper type.
<Switch Millimeter/Inch Entry>
<Preferences>
<Display Settings>
You can set whether to enter numeric values in millimeters or inches on the various numeric entry screens.
<Display Logged-in User Name>
<Preferences>
<Display Settings>
You can select whether to display the user name/display name on the touch panel display.
<IP Address Display Settings>
<Preferences>
<Display Settings>
You can set whether to display the IP address on the counter information screen.
<Display Scan for Mobile>
<Preferences>
<Display Settings>
You can set whether to enable the <Scan for Mobile> setting, which sends scanned data to mobile devices such as smartphones and tablets.
<Display Mobile Portal>
<Preferences>
<Display Settings>
You can set whether to display <Mobile Portal> on the Main Menu screen.
<Display QR Code on Mobile Portal>
<Preferences>
<Display Settings>
You can set whether to display a QR code on the <Mobile Portal> screen. Using a QR code saves you the effort of entering the IPv4 address of the machine.
