, the Main Menu is displayed, and a list of function buttons is shown. The Main Menu displays a list of function buttons. You can change the functions for these buttons or rearrange their positions so that you can easily choose frequently used functions or hide functions not used often. Customizing the Main Menu
Shortcut
Function button list
to display the <Settings/Registration> screen. Press this key first to make changes for each setting, such as paper settings, display settings, and network settings. On this screen, you can also register destinations, such as e-mail addresses and fax numbers.
Current menu level
Setting item list
, the <Status Monitor/Cancel> screen is displayed. On this screen, you can check the printing status and transmission status, as well as the remaining amount of toner and memory level.
Status and logs of copy/print/transmission/saved documents
Consumables
Operation guide
Message/Icon|
USB memory device is connected Connecting a USB Memory Device
Replacement of toner is necessary Replacing the Toner Cartridge
<Switch Language/Keyboard> button Showing the <Switch Language/Keyboard> Button on the Touch Panel Display
TIPS
Press
displayed on the Main Menu and the Basic Features screen to customize the screen such as rearranging buttons or creating a shortcut key. Only an Administrator can customize the Main Menu. Customizing the Touch Panel Display![]() You can change settings regarding the screen display, such as which screen appears immediately after turning ON the machine, and whether the message appears for remaining paper and toner. <Display Settings>
You can set the screen to be displayed when a certain amount of time has passed without operation. <Function After Auto Reset>
