<Send>
<E-Mail/I-Fax Settings>
<Communication Settings>.
<SMTP RX>
<SMTP Server>
<E-Mail Address>
<POP Server>
<POP Login Name>
<POP Password>
<POP Interval>
<Authent./Encryption>
<POP>
Setting POP authentication before sending and encryption communication to/from the POP server
1
Press <Authent./Encryption>.
2
Specify each item.
![]() <POP Auth. Method>Set the authentication methods of the POP3 server. To encode the password during authentication, select <APOP>. To authenticate users when receiving mail (POP), select <POP AUTH>.
<POP Authentication Before Sending>To perform authentication using the POP3 server, press <On>.
<Allow TLS (POP)>To encode the communication to/from the POP3 server using TLS, press <On>. When <On> is set, you can confirm the TLS server certificate during communication with the server and add CN to the verification items. <E-Mail/I-Fax Settings>
<Confirm TLS Certificate for POP RX> |
3
Press <OK>.
Setting SMTP authentication and encryption communication to/from the SMTP server
1
2
Specify each item.
![]() <SMTP Authentication (SMTP AUTH)>To use SMTP authentication, press <On>, enter the user name and password of the specified mail accounts in <User Name> and <Password>.
NOTE:
When making settings for each registered user
You can set user names/passwords to be used in SMTP authentication for each registered user or division ID (Registering User Information in the Local Device). When you want to use the user names in the specified mail account of the machine which is set in <SMTP Authentication (SMTP AUTH)>, change the authentication methods during server authentication. (Configuring the User Login Methods and Authentication Devices)
<Allow TLS (SMTP RX)>To encode communication using TLS when receiving e-mails and I-faxes using the SMTP server, press <Always TLS> or <On>. When you don't want to receive data other than encoded data, select <Always TLS>.
<Display Auth. Screen When Sending>When sending e-mails and I-faxes, to display the user name and password entry screen, press <On>.
<Allow TLS (SMTP TX)>To encode the communication to/from the SMTP server using TLS, press <On>. When <On> is set, you can confirm the TLS server certificate during communication with the server and add CN to the verification items. <E-Mail/I-Fax Settings>
<Confirm TLS Certificate for SMTP TX> |
3
Press <OK>.
Depending on your environment, you might need to specify the SMTP/POP3 port number. When you use Office365, set the SMTP sending port number to "587". For details, contact the Internet service provider or the network administrators.
