<Common>
This section describes settings for functions such as Paper Feed Settings, Paper Output Settings, Print Settings, Scan Settings, and Generate File.
<Paper Drawer Auto Selection On/Off>
<Function Settings>
<Common>
<Paper Feed Settings>
When copying/printing with the machine, a paper source loaded with the required paper size can be automatically selected and another paper source loaded with the same paper can be automatically switched to when paper runs out. This setting enables the paper source to be automatically switched for each function, such as the Copy or Print function.
Automatically Selecting the Appropriate Paper Source for a Specific Function
<Switch Feed Method>
<Function Settings>
<Common>
When using paper with different front and reverse sides, such as paper with a logo printed on it, you can set this to <Print Side Priority> to print the first page to the front side for both one-sided and two-sided printing, without having to change the paper orientation.
The settings for Automatic Paper Selection and Auto Drawer Switching are disabled for paper sources with <Print Side Priority> set. The print speed is also slower when performing one-sided printing.
<Suspended Job Timeout>
<Function Settings>
<Common>
If this setting is set to <On> and a job is suspended due to a paper jam, etc., the machine automatically prints the next job after the specified time period.
If a job is suspended because paper has run out during the job, the next job is not processed even after the designated suspension time elapses.
<Offset Jobs>
<Function Settings>
<Common>
<Paper Output Settings>
This enables you to shift the output for each job when multiple jobs are printed consecutively.
<Job Separator Between Jobs>
<Function Settings>
<Common>
This enables you to insert the specified paper at the start of each job when multiple jobs are printed consecutively.
<Job Separator Between Copies>
<Function Settings>
<Common>
This enables you to insert the specified paper each number of copy sets to divide the sets. If you set this, paper is inserted when printing with Collate (Page Order), Offset, or Staple.
You cannot insert job separation sheets between copy sets in the following cases: If you are using the Group
<Action When Too Many Sheets to Staple>
<Function Settings>
<Common>
You can specify the procedure to perform when there are too many sheets to staple.
<Print Priority>
<Function Settings>
<Common>
<Print Settings>
A job that has a higher set priority can be set to print after the job currently being processed is complete.
If the same printing priority has been specified for multiple functions, printing starts with the first processed print job.
Priority printing does not take place until the current job is complete. However, if the current job is paused, the printing of another job may start, depending on its settings.
<Text/Photo Priority When Recognized as B&W by ACS>
<Function Settings>
<Common>
<Print Settings>
You can set the quality to use when an original is detected to be black-and-white with auto color selection.
<2-Sided Printing>
<Function Settings>
<Common>
<Print Settings>
<Output Report Default Settings>
You can specify the 2-Sided Printing for printing reports such as Send TX Report and Communication Management Report.
<Register Characters for Page Numbering/Watermark>
<Function Settings>
<Common>
<Print Settings>
You can register/edit/delete user-defined text for <Page Numbering>/<Watermark>. It is useful if you always use the same text or watermark for <Watermark> in <Secure Watermark>, and <Page Numbering> and <Watermark> in the Copy function.
<Copy Set Numbering Option Settings>
<Function Settings>
<Common>
<Print Settings>
In addition to Copy Set Numbering, you can add User Name, Date, and Text on the printout.
<Forced Print of Recognition Information>
<Function Settings>
<Common>
<Print Settings>
You can force to print the user ID, date, IP address, or serial number of the machine on the printout.
Printing User Information on Documents Embedding Invisible Text (Forced Secure Watermark)
IPv6 addresses cannot be printed.
<Forced Secure Watermark/Document Scan Lock>
<Function Settings>
<Common>
<Print Settings>
<Secure Watermark/Document Scan Lock>
Secure Watermark/Document Scan Lock enables you to prevent information leakage. These functions can be set by administrator so that it is always reflected on the output by the general users.
Embedding Information That Restricts Copying (Forced Document Scan Lock)
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
<Printer Driver Watermark/Document Scan Lock>
<Function Settings>
<Common>
<Print Settings>
When printing from a printer driver, you can select the functions set here for each job.
If <Printer Driver Secure Watermark> and <Forced Secure Watermark> are set for a printer at the same time, Forced Secure Watermark is given priority.
If a login service has been set, the user name/Department ID of the user who logged in is printed.
The watermark <CONFIDENTIAL> is printed if a login service is not set.
To use this function, specify the following settings in the printer driver in advance. For details, see the help for the printer driver.
<Standard>
<Function Settings>
<Common>
<Print Settings>
<Adjust Background/Character Contrast>
Adjusts the relative contrast of the hidden text and the background. The Secure Watermark effect can be tested by making a copy of a sample print. The following settings are specified here.
<Relative Contrast>: Adjusts the relative contrast of the hidden text and the background.
<Standard Value Settings>: Sets the density of the background.
<Latent Area Density>: Sets the density of the text.
Load A4, LTR size plain or heavy paper when making sample prints.
Sample Print
The sample print includes the hidden text and the background for each relative contrast value.
The area within the frame on the sample print is the output sample for the currently set relative contrast value.
Relative Contrast
Adjust the relative contrast while comparing the difference between the set standard value and the current latent area density, by referring to the sample print.
If you increase the value for the relative contrast, the background gets denser, and if you decrease the value, the background gets lighter. When you select <White Letters on Colored Bkground.>, if you increase the value for the relative contrast, the text becomes denser, and if you decrease the value, the text becomes lighter.
<Print Settings>
If you select <White Letters on Colored Bkground.>, set the standard value for the density of the text and the latent area density for the density of the background.
If you increase the value for the standard value, the background gets denser, and if you decrease the value, the background gets lighter. When <White Letters on Colored Bkground.> is selected, if you increase the standard value, the text gets denser, and if you decrease the value, the text gets lighter.
When changing the adjustment area on the sample print for the relative contrast, specify settings for <Standard Value Settings>.
If you changed the standard value, adjust <Latent Area Density> so that the density of the inner square set in the standard value for the standard value sample print gets closer.
To set a background density that differs from the most even secure watermark image in the standard value sample print, it is necessary to adjust <Latent Area Density> to a density close to the background density.
If you increase the value for <Latent Area Density>, the text becomes denser, and if you decrease the value, the text becomes lighter. When <White Letters on Colored Bkground.> is selected, if you increase the value in <Latent Area Density>, the background gets denser, and if you decrease the value, the background gets lighter.
<For Printer 1200 dpi>
<Function Settings>
<Common>
<Print Settings>
Sample Print
Relative Contrast
<Print Settings>
<Standard>
<Function Settings>
<Common>
<Print Settings>
<Adjust TL Code>
You can adjust the density of the TL code to be embedded in the document.
Using TL Code to Restrict Copying
<Function Settings>
<Common>
<Print Settings>
<Adjust TL Code>
<QR Code Print Position>
<Function Settings>
<Common>
<Print Settings>
You can specify the position of a QR code.
Using QR Code to Restrict Copying
<Quickly Exit Sleep Mode for Print Job>
<Function Settings>
<Common>
<Print Settings>
If you perform LPD/RAW printing while the machine is in sleep mode, it may take some time to start printing. If this setting is set to <On>, this time can be reduced.
<Auto Delete Suspended Jobs>
<Function Settings>
<Common>
<Print Settings>
If this setting is set to <On> and a job is suspended due to a paper jam, etc., the machine automatically deletes the job after the specified time period.
<Feeder Jam Recovery Method>
<Function Settings>
<Common>
<Scan Settings>
You can select whether scanning will start again from the first page of the original or the page of the original in which scanning was interrupted if a paper jam occurs in the feeder.
Direct sending of faxes does not support this setting. If a paper jam occurs while performing direct sending, the job will be canceled. In this case, set the job again.
Depending on the location of a paper jam, it can be difficult to determine whether document scanning has been completed. If you have set <From Suspnd. Original> for <Feeder Jam Recovery Method> and you do not find until which page the document has been scanned, it is ecommended that you cancel the job, and then execute it again.
<Set Detection of Feeder Multi. Sheet Feed as Default>
<Function Settings>
<Common>
<Scan Settings>
<Streak Prevention>
<Function Settings>
<Common>
<Scan Settings>
You can set whether to detect and prevent streaks when scanning originals.
When <On> is selected, extremely thin lines may be detected as streaks.
<Speed/Image Quality Priority for B&W Scan>
<Function Settings>
<Common>
<Scan Settings>
You can set whether priority is given to scanning speed or to image quality when performing black and white scanning.
<Feeder Scan Speed/Image Quality Priority>
<Function Settings>
<Common>
<Scan Settings>
You can set whether priority is given to scanning speed or to image quality when scanning originals from the feeder.
<Remote Scan Gamma Value>
<Function Settings>
<Common>
<Scan Settings>
You can set the gamma value to use when scanning color documents into your computer through the Network Scan function. Select the gamma value most suited to your computer settings so that you can print the document with the optimal density.
<Auto Online>
<Function Settings>
<Common>
<Scan Settings>
Set this to <On> to automatically enable the remote scanner function when you press <Scanner> on the Main Menu screen.
When the remote scanner function is enabled, you cannot use <Copy> and <Scan and Store>.
You can specify the time period in which you are logged out and the touch panel display returns to the default setting automatically.
<Auto Offline>
<Function Settings>
<Common>
<Scan Settings>
If the machine is connected to a network that is online, scanning is not possible with <Copy> or <Scan and Store>. If you set <Auto Offline> to <On>, the machine automatically goes offline when the time set in <Auto Reset Time> in <Preferences> (Settings/Registration) has elapsed.
If <Auto Reset Time> is set to <0>, the machine automatically goes offline after approximately two minutes.
<Image Quality Level for Compact>
<Function Settings>
<Common>
<Generate File>
If you select PDF/XPS (Compact) as the file format when using <Scan and Send> or <Scan and Store>, you can set the image quality level of the document.
This setting is disabled when sending a fax or I-fax.
If you scan an original with many colors when <Text> is selected for the original type, the data size and image quality will vary following compression, according to the selected image level. However, if the original is in monochrome or has few colors, it does not matter which image level you select.
<OCR (Text Searchable) Settings>
<Function Settings>
<Common>
<Generate File>
If you select <OCR (Text Searchable)> for <PDF> or <OOXML> as the file format, you can set the Smart Scan setting, and set the number of characters for the Auto (OCR) in File Name. Smart Scan is a mode that determines the text direction to detect the alignment when sending a document. Auto (OCR) in File Name is a mode that automatically uses the first text scanned by OCR in the document as its file name. The file name is specified in <File Name> in <Options> on the Scan and Send screen.
You cannot use the Auto (OCR) in File Name mode and the Encrypted PDF mode at the same time when sending a file.
<Trace & Smooth Settings>
<Function Settings>
<Common>
<Generate File>
You can change the recognition rate of line drawings of the original when creating a file with outline graphics.
If you increase the value in <Graphics Recognition Level>, the data size also increases. It is recommended that you first use <Normal>, and if desirable results are not obtained, try increasing the recognition level to <Moderate> or <High>.
<OOXML Settings>
<Function Settings>
<Common>
<Generate File>
You can set the color graphics and background images when creating files with OOXML file format.
<Include Background Images in Word File>
<Function Settings>
<Common>
<Generate File>
You can set whether to erase background images when generating Word files from scanned originals. Setting <Off> enables you to generate Word files which are easy to edit as unnecessary images are deleted.
<Specify Minimum PDF Version>
<Function Settings>
<Common>
<Generate File>
You can specify the minimum version to assign when generating PDF files.
Depending on the functions set for the PDF files, the version assigned may be higher than that specified with this setting.
<Format PDF to PDF/A>
<Function Settings>
<Common>
<Generate File>
You can create PDF files compliant with PDF/A-b1. This is suited for long-term storage because it guarantees that the visual quality of the PDF does not change with the machine or viewing software.
This setting is linked with the default setting for <File Format> in <Scan and Send>, <File Format> for <Send> in <Access Stored Files>, and for <File Format> in <Forwarding Settings>.
This setting is always applied to <File Format> in <Scan and Store>. It cannot be specified for individual jobs.
The following PDF functions cannot be set if <Format PDF to PDF/A> is set to <On>.
Encryption
Visible Signature
<Optimize PDF for Web>
<Function Settings>
<Common>
<Generate File>
You can create a PDF that displays only the pages that are already downloaded even when a file is still being downloaded.
If you set <Optimize PDF for Web> to <On>, this setting can be used with one of the following settings:
Device Signatures
User Signatures
<256-bit AES Settings for Encrypted PDF>
<Function Settings>
<Common>
<Generate File>
When generating an encrypted PDF file, you can select <Acrobat 3.0 or Later/40-bit RC4>, <Acrobat 6.0 or Later/128-bit RC4>, <Acrobat 7.0 or Later/128-bit AES>, or <Acrobat 10.0 or Equivalent/256-bit AES> as the PDF encryption level. If you want to use <Acrobat 9.0 or Equivalent/256-bit AES> rather than <Acrobat 10.0 or Equivalent/256-bit AES> as the encryption level, use this setting to change the selections you can make.
<Rights Management Server Settings>
<Function Settings>
<Common>
<Generate File>
This machine can link with Adobe LiveCycle Rights Management to generate PDF files that have viewing and other privileges managed.
Adobe LiveCycle Rights Management ES series software is required to use this setting. For more information, contact your local authorized Canon dealer.
To use this setting, the Adobe LiveCycle Rights Management server and this machine must be connected via the Internet or an intranet.
For information on the IP address, host name, and port number, contact the administrator of the Adobe LiveCycle Rights Management server.
<Use Document Scan Lock>
<Function Settings>
<Common>
<Doc. Scan Lock Operation Settings>
You can select the TL code or QR code for Document Scan Lock.
<Document Scan Lock TL Code Settings>
<Function Settings>
<Common>
You can configure the settings for TL code.
If you convert a document with a TL code embedded to a generic file format (such as PDF and TIFF) using the functions described in <Scan and Send> or <Scan and Store>, the embedded information is not retained. Therefore, when you print the file after it has been converted, the settings in <Doc. Scan Lock Operation Settings> are not reflected.
You can analyze the embedded information using the Document Scan Code Analyzer for MEAP that is supplied with the Document Scan Lock Kit. For more information, see the manual for Document Scan Code Analyzer for MEAP.
<Document Scan Lock QR Code Settings>
<Function Settings>
<Common>
You can configure the settings for QR code.
<Information Used for LDAP Server Authentication>
<Function Settings>
<Common>
<Set Authentication Method>
You can specify the authentication method for accessing an LDAP server.
<Device Login Authentication Information> is available only when using the same authentication information for logging in to the machine and accessing the LDAP server, and when using a login service which supports Integrated Authentication. For information whether the login service you are using supports Integrated Authentication, contact your local authorized Canon dealer.
<Information Used for Rights Management Server Auth.>
<Function Settings>
<Common>
You can specify the authentication method for accessing a Rights Management server.
<Information Used for SMTP Server Authentication>
<Function Settings>
<Common>
You can specify the authentication method for accessing an SMTP server.
<Information Used for File TX/Browsing Authentication>
<Function Settings>
<Common>
You can specify the authentication method for accessing a file server.
