and
and press <Details>. To delete a destination from the specified destinations, press <Delete Dest.>.
<Remote>.
Destination type buttons
and
displays fax and group destinations, respectively.
Drop-down list for selection of Address Book types
<Search by Name>
Search buttons by first letter
If you select the group destination containing destinations other than fax destinations, sending a fax is not allowed.
and enter the number for the desired one-touch button.
To send faxes overseasEnter the international access number, the country code, and the fax number, in that order. If you cannot successfully connect to the destination overseas, press <Pause> to insert a pause between a number and the next number.
To send faxes with a subaddressThe machine supports the use of ITU-T* standard subaddresses. If the recipient's fax machine is compatible with the use of ITU-T subaddresses, you can enhance the confidentiality of sent documents using a subaddress and password. To send a document with a subaddress, enter a fax number, press <Subaddress> or <Set Details>, and then enter the subaddress and password.
* Stands for International Telecommunication Union-Telecommunication Standardization Sector, which is the group that makes recommendations towards the standardization of worldwide telecommunications.
<LDAP Server>.
Search categories
Search conditions
Search characters
If you are scanning free size/highly transparent originals, or the edge of image is missing when scanning, you need to manually specify the scanning size.
Specifying the Scanning Size of Originals
The machine can automatically scan both the front and back sides of an original.
Scanning Both Sides of Originals
To register the scanning sizeIf you frequently specify the scanning size with the same values, register the size in <Custom>
<Register Size> to quickly recall the setting for convenience. |
<2-Sided Original>.
You can select the resolution suitable for your type of original. The higher the resolution is, the clearer the image becomes, but the longer it takes to send.
Selecting Resolution
Specifying the type of original such as documents with characters only or magazines with photographs enables you to send with optimal image quality.
Selecting the Type of Original
You can adjust the density of the entire original. For example, increasing the density enables you to easily read faint characters written in pencil.
Adjusting the Density of the Entire Original
You can adjust the density of the background. You can clearly send originals with a colored background or thin originals such as newspapers whose characters and images on the back side are transparently visible.
Adjusting the Density of the Background
You can scan the image with clear contours and lines by increasing the sharpness, or soften the image by decreasing the sharpness. Use this function when you want to sharpen blurred text and diagrams, or to reduce moire (a shimmering, wavy pattern) to smoothen the finished image.
Adjusting Sharpness (Sharpness)
<Original Type>.
<Density>.
to decrease the density. Press
to increase the density.
<Density>.
<Close>.
<Sharpness>.
Place the original with punch holes on the platen glass. Placing in the feeder may result in damage.
<Erase Frame>.|
1
Press <Erase Original Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the original, press <Change> to select the size.
2
Enter the width of the frame to erase.
1
Press <Erase Book Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the book, press <Change> to select the size.
2
Press <Center> or <Sides> and enter each erasing width.
1
Press <Erase Binding> and select the punch hole location.
2
Enter the erasing width.
If you want to adjust the width for each border independently, press <Erase Original Frame> or <Erase Book Frame>, and then press <Adjust Independently> to enter the erasing widths.
<Close>.
<Yes>.
. When scanning all of the originals is complete, press <Start Sending> to send the fax.
To send with the sender informationYou can send with the sender's name and fax number. <TX Terminal ID>
To check the statuses for sent documentsOn the <Status Monitor/Cancel> screen, you can check the statuses for sent documents. This screen enables you to send faxes again or cancel sending after checking the statuses. Checking Status and Log for Sent and Received Documents
When <Display Notification When Job Is Accepted> is set to <On>, the <Status Monitor/Cancel> screen can be displayed from the following screen that is shown after a send job is received. <Display Notification When Job Is Accepted>
![]() When a transmission error occurs because the recipient's line is busyThe machine automatically redials after a certain period of time. You can change the settings such as how many times the machine redials and the interval between redials. <Auto Redial>
To print the report for the results of sendingOn the Fax Basic Features screen, pressing <Options>
<TX Report> enables you to set to automatically print the report listing the results of sending.When multiple sheets are fedScanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Fax Basic Features screen
<Detect Feeder Multi Sheet Fd.> each time you send a document to disable the setting, or set <Set Detection of Feeder Multi. Sheet Feed as Default> to <Off> (<Set Detection of Feeder Multi. Sheet Feed as Default>). |
TIPS
Saving a copy of a sent documentYou can set the machine so that a copy of a sent document is automatically saved in a file server. The copy is converted into an electric file such as PDF and saved, allowing you to easily check the contents from your computer. Saving a Copy of a Sent Document
Selecting a sender's nameOn the Basic Fax Features screen, pressing <Options>
<Sender Name (TTI)> enables you to select a name from a list of registered sender's names to include in the sender information. <Register Sender Name (TTI)>Checking scanned images before sendingYou can check scanned images on the preview screen before sending. Checking Scanned Images Before Sending (Preview)
Registering frequently used settingsYou can combine frequently used destinations and scan settings into a button of the machine for later use. By pressing the registered button when scanning originals, you can quickly complete your settings. Registering a Combination of Frequently Used Functions
