Settings/Registration
You can customize the machine based on your environment and needs by configuring settings described in this chapter. To start configuration, press .
This section describes what each item in the setting menu can configure.
Some of the settings may not be displayed depending on the configuration of optional equipment installed on the machine.
You may need to press <Apply Set. Changes> on the Top screen of the Settings/Registration or restart the machine to activate certain functions after changing the settings.
<Personal Settings> and <Device Settings>
When User Authentication (Managing Users) is enabled, <Personal Settings> and <Device Settings> are displayed on the screen after you log in with Administrator privileges by pressing . If you select <Personal Settings> and change the items that can be personalized, settings are registered as the personal settings for the user who is logged into the machine (List of Items That Can Be Personalized). If you select <Device Settings>, settings are registered as the settings of the machine. If you log in as a user without Administrator privileges, just like when selecting <Personal Settings>, if you change settings that can be personalized, settings are registered as personal settings without being registered as device settings.
1A94-0E1
