You can bind each copy with the stapler after a collate or group output.
<Next>.
Depending on finishing functions, the installation of optional devices is needed. Optional Equipment
Depending on the paper type, you cannot use finishing functions. Specifications
You can specify the procedure to perform when there are too many sheets to staple at once. <Action When Too Many Sheets to Staple>
