Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Hold
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Distinguishing A5R and STMTR Paper
Distinguishing B5 and EXEC Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Defaults
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Switching the Copy Basic Features Screen
Display Fax Function
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Changing the Puncher Die Name
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Energy Saver/Sleep Mode Exit Time
Switching Modes Activated After Pressing Energy Saver Key
Change Energy Saver Mode
Setting the Silent Mode Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Automatic Gradation Adjustment
Correct Density
Fine Adjust Zoom
Adjust Action
Saddle Stitch Position Adjustment
Saddle Stitch Fold Placement Adjustment
Double Staple Width Adjustment
Finisher Puncher Switch
Speed/Precision Priority for Double Staple
Adjusting the Trimming Width
Adjusting the Paper Folding Position
Size Change Plate Width Adjustment
Paper Alignment When Stapling
Paper Alignment on Finisher Tray A/B
Changing the Finisher Output Priority Settings (Heavy 2,3)
Changing the Finisher Output Priority Settings (Thin)
Maintenance
Automatic Feeder Cleaning
Wire Cleaning
Drum Cleaning
Checking the Procedure for Cleaning the Original Scanning Area of the Feeder
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
High Volume Stack Mode
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Outputting Different Sized Papers to the Same Output Tray
Aligning Output Paper of Different Width
Forcing to Output Excess Tab Paper
Print Settings
Setting the Printing Priority
Specifying the Thin/Plain Paper Printing Priority Settings
Specifying the Default Settings for Printing from the Remote UI
Outputting Reports with Two-Sided Printing
Registering Forms for the Superimpose Image Mode
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Scan Settings
Timing to Raise Feeder Tray
Feeder Jam Recovery Method
Scanner Noise Settings
Streak Prevention
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
High Compression Image Quality Level
Settings for Creating Searchable PDF/XPS/OOXML
Trace & Smooth Settings
OOXML Settings
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Registering Express Copy Shortcut Buttons
Enabling Auto Collating
Giving Priority to Image Orientation
Enabling Auto Orientation
Copying with the Printed Image Mode
Setting a Printer for Cascade Copying
Cascade Copy Communication Timeout
Send
Outputting Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Send
Changing the Default Settings for Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data Into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN upon Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Autocomplete for E-mail Address Entry
Specifying the Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for the Fax Function
Registering/Editing/Deleting Sender Names
Setting the Authenticated User Name as the Sender Name (TTI)
Enabling ECM Transmission
Pause Time
Enabling Auto Redial
Checking the Dial Tone Before Sending
Fax TX Report
Fax Activity Report
Fax Line Settings
Setting the Line to Use When Sending
Send Start Speed
PIN Code Access
Remote Fax TX Settings
Enabling Remote Fax
Receive/Forward
Outputting Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Editing Forwarding Settings
Printing Forwarding Settings
Specifying the Fax/I-Fax Inbox Settings
Always Send Notice for RX Errors
Enabling ECM Reception
Fax RX Report
Confidential Fax Inbox RX Report
Setting the Receive Start Speed
Setting the Receive Password
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Mail Box Settings
Memory Media Settings
Hold
Specifying the Hold Function
Setting the Time Until a Hold Job is Automatically Deleted
Storing Jobs with PS/PDF Data in the Hold Queue
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Settings/Registration Table » Function Settings » Function Settings: Printer
08KE-04R
The following table lists all settings of the Printer Settings menu.
Output Report
Item
Settings
Default Settings
Can be set in Remote UI
Device Information
Delivery Available
PCL*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
PS*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
*1
Indicates items that appear only when the appropriate optional product is available for use or the appropriate setting is specified.
Common Settings (Printer Settings > Custom Settings)
Item
Settings
Default Settings
Can be set in
Remote UI
Device Information
Delivery Available
[Copies]
1 to 9999
1
Yes
Yes
[2-Sided Printing]
On, Off
Off
Yes
Yes
[Paper Feed]
[Default Paper Size]
Letter, Legal, A4, B5, A3, B4, A5, 11x17, Executive, Statement, 12.60x17.72, 12x18, 13x19
Letter
Yes
No
[Default Paper Type]
Thin, Plain, Heavy 1, Heavy 2, Heavy 3, Color, Recycled, Letterhead, Tracing, Transparency, Labels, Bond, Tab, Pre-Punched
Plain
Yes
No
[Paper Size Override]
On, Off
Off
Yes
Yes
[Paper Output]
[Finishing]
Off, Collate, Group, Rotate+Collate, Rotate+Group, Offset+Collate, Offset+Group, Staple+Collate, Staple+Group
Staple Position (Staple+Collate):
Corner (Upper-L), Double (Top), Corner (Upper-R), Double (Right), Corner (Lower-R), Double (Bottom), Corner (Lower-L), Double (Left)
Staple Position (Staple+Group):
Grp Upp L-Corner, Grp Double (Top), Grp Upp R-Corner, Grp Double (R), Grp Lwr R-Corner, Grp Double (Btm), Grp Lwr L-Corner, Grp Double (L)
Group
Yes
Yes
[Punch]
Off, Top, Bottom, Left, Right
Off
Yes
Yes
[Fold]
Off, Z-Fold, C-Fold
Off
Yes
No
[Face Up/Down]
Face Down, Face Up
Face Down
Yes
Yes
[Print Quality]
[Image Refinement]
On, Off
On
Yes
Yes
[Density]*1
-8 to 8
0
Yes
Yes
[Density (Fine Adjust)]*1
High:
-8 to 8
Medium:
-8 to 8
Low:
-8 to 8
0
Yes
Yes
[Toner Save]
On, Off
Off
Yes
Yes
[Line Refinement]
On, Off
Off
Yes
Yes
[Horizontal Line Refinement]
Off, Level 1, Level 2, Level 3, Level 4
Off
Yes
Yes
[Vertical Line Refinement]
Level 1
Yes
Yes
[Resolution]
1200 dpi, 600 dpi
600 dpi
Yes
Yes
[Layout]
[Binding Location]
Long Edge, Short Edge
Long Edge
Yes
Yes
[Gutter]
-1.90 to +1.90 inches
0.00
Yes
Yes
[Offset Short Edge (Front)]
-2.00 to +2.00 inches
0.00
Yes
Yes
[Offset Long Edge (Front)]
0.00
Yes
Yes
[Offset Short Edge (Back)]
0.00
Yes
Yes
[Offset Long Edge (Back)]
0.00
Yes
Yes
[Auto Error Skip]
On, Off
Off
Yes
Yes
[Secure Print Delete Time]
10 minutes, 20 minutes, 30 minutes, 1 hour, 2 hours, 3 hours, 6 hours, 12 hours, 24 hours
1 hour
Yes
Yes
[Timeout]
Timeout (5 to 300 seconds), Off
15 seconds
Yes
Yes
[Print After Completing RIP]
On, Off
Off
Yes
Yes
[Booklet]
On, Off
Off
Yes
Yes
[Saddle Stitch]*1
On, Off
Off
Yes
Yes
[Creep Correction]*1
Off, Auto, Correction Width
Off
Yes
Yes
[Use Cover Inserter]*1
Off, Inserter 1, Inserter 2
Off
Yes
No
[Transparency Interleaving]*1
(See "Transparency Interleaving.")
Off, Blank, Printed
Off
Yes
Yes
[Copy Set Numbering]
On, Off
Off
Yes
Yes
[Print Position]*1
5 Locations, Top Left, Bottom Left, Top Right, Bottom Right, Full Surface
5 Locations
Yes
Yes
[Starting Number]*1
1 to 9999
1
Yes
Yes
[Number Size]*1
[Small(12 point)], [Medium(24 point)], [Large(36 point)]
Large(36 point)
Yes
Yes
[Density]*1
1 to 5
3
Yes
Yes
[Number Position Vertical]*1
-5/16 to +5/16 inches
0
Yes
Yes
[Number Position Horizontal]*1
0
Yes
Yes
[Personality]*1
Auto, PS, PCL, Imaging, PDF, XPS
Auto
Yes
No
[Mode Priority]*1
(See "Mode Priority.")
None, PS, PCL, PDF, XPS
None
Yes
No
[Initialize]
Yes, No
No
Yes
*1
UFR II Settings (Printer Settings > Custom Settings > UFR II)
Item
Settings
Default Settings
Device Information
Delivery Available
[Halftones]
Text: Color Tone, Gradation, Resolution, High Resolution
Resolution
Yes
Yes
Graphics: Color Tone, Gradation, Resolution, High Resolution
Color Tone
Image: Color Tone, Gradation, Resolution, High Resolution
Color Tone
[Paper Save]
On, Off
On
Yes
Yes
PCL Settings (Printer Settings > Custom Settings > PCL) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Paper Save]
On, Off
Off
Yes
Yes
[Orientation]
Portrait, Landscape
Portrait
Yes
Yes
[Font Number]
0 to 104
0
Yes
No
[Point Size]*1
4.00 to 999.75 point
12.00 point
Yes
No
[Pitch]*1
0.44 to 99.99 cpi
10.00 cpi
Yes
No
[Form Lines]
5 to 128 lines
60 lines
Yes
No
[Character Code]
ARABIC8, DESKTOP, GREEK8, HEBREW7, HEBREW8, ISO4, ISO6, ISO11, ISO15, ISO17, ISO21, ISO60, ISO69, ISOCYR, ISOGRK, ISOHEB, ISOL1, ISOL2, ISOL5, ISOL6, LEGAL, MATH8, MCTEXT, MSPUBL, PC775, PC8, PC850, PC851, PC852, PC862, PC864, PC866, PC8DN, PC8GRK, PC8TK, PC1004, PIFONT, PSMATH, PSTEXT, ROMAN8, VNINTL, VNMATH, VNUS, WIN30, WINARB, WINBALT, WINCYR, WINGRK, WINL1, WINL2, WINL5
PC8
Yes
Yes
[Custom Paper]
On, Off
Off
Yes
No
[Unit of Measure]*1
Millimeters, Inches
Inches
Yes
No
[X dimension]*1
5.82 to 24.80 inches
19.20 inches
Yes
No
[Y dimension]*1
3.93 to 13.00 inches
13.00 inches
Yes
No
[Append CR to LF]
Yes, No
No
Yes
Yes
[Enlarge A4 Print Width]
On, Off
Off
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Color Tone
Color Tone
Enable, Disable
Disable
Yes
Yes
Off, ~, ", #, $, /, \, ?, {, }, |
Yes
Yes
*1
*2
PCL Printer only.
PS Settings (Printer Settings > Custom Settings > PS) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Job Timeout]
0 to 3600 seconds
0
Yes
Yes
[Print PS Errors]
On, Off
Off
Yes
Yes
[Halftones]
Text: Gradation, Resolution, High Resolution
Resolution
Yes
Yes
Graphics: Gradation, Resolution, High Resolution
Resolution
Image: Gradation, Resolution, High Resolution
Resolution
[Grayscale Conversion]*1
sRGB, NTSC, Uniform RGB
NTSC
Yes
Yes
[Dot Gain Adjustment]
-10%, -5%, Standard, +5%, +10%
Standard
Yes
No
*1
*2
PS Printer only.
Imaging Settings (Printer Settings > Custom Settings > Imaging) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Image Orientation]
Auto, Vertical, Horizontal
Auto
Yes
Yes
[Zoom Mode]
Off, Auto
Off
Yes
Yes
[Print Position]
Auto, Center, Top Left
Auto
Yes
Yes
[Show Warnings]
On, Off
On
Yes
Yes
[Enlarge Print Area]
On, Off
Off
Yes
Yes
[Halftones]
Gradation
Yes
Yes
NTSC
Yes
Yes
*1
*2
Settings are applicable only for the Imaging mode of Direct Print.
PDF Settings (Printer Settings > Custom Settings > PDF) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Enlarge/Reduce to Fit Size]
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[N on 1]
Off, 2 on 1, 4 on 1, 6 on 1, 8 on 1, 9 on 1, 16 on 1
Off
Yes
Yes
[Comment Print]
Off, Auto
Auto
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Resolution
Resolution
NTSC
Yes
Yes
Standard
Yes
No
*1
*2
PS Printer only.
XPS Settings (Printer Settings > Custom Settings > XPS) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Halftones]
Resolution
Yes
Yes
Resolution
Resolution
Text: sRGB, NTSC, Uniform RGB
sRGB
Yes
Yes
Graphics: sRGB, NTSC, Uniform RGB
sRGB
Image: sRGB, NTSC, Uniform RGB
sRGB
*1
*2
XPS Direct Print Printer only
Utility Settings (Printer Settings > Utility)
Item
Settings
Default Settings
Device Information
Delivery Available
[Initialize PCL Hard Disk]*1
Yes, No
No
No
[Initialize PS Hard Disk]*1
Yes, No
No
No
[Reset Printer]
Yes, No
No
No
*1
Printer Menu
Item
Settings
Default Settings
Device Information
Delivery Available
[Restrict Printer Jobs]
On, Off
Off
Yes
Yes
When On is selected:
Select Jobs to Allow: Rsrvd Jobs, Rsrvd Jobs + Secure Print
Rsrvd Jobs
Yes
Yes
[PDL Selection (Plug-n-Play)]
UFR II, PCL5e*1, PCL6*1, PS3*1, Fax*1, UFR II (XPS)
UFR II
Yes
No
*1
