Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows 2000/XP/Server 2003/Server 2008/Vista/7/Server 2008 R2
Mac OS X 10.3.9 or Later
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2
Top » Network » Checking Your Network Environment
08KE-1RY
Refer to the following examples to confirm the network environment that is connected to the machine, and then perform the necessary operations for that environment.
Sample Windows Network
In a Windows network environment, the TCP/IP or NetBIOS (NetBIOS over TCP/IP) protocol can be used. Multiple protocols can be used at the same time. In addition to IPv4 (Internet Protocol Version 4), the machine also supports IPv6 (Internet Protocol Version 6), and has a dual stack configuration that enables it to communicate with both IPv4 networks and IPv6 networks. You can select whether to use the functions of IPv4 or IPv6. You can also enable the functions of both IPv4 and IPv6. The IPv4 network and IPv6 network used by the machine support IPSec (Security Architecture for Internet Protocol). (See "IPSec Settings.")
To use the e-mail/I-fax function, the TCP/IP protocol is required.
After configuring the settings in accordance with "Connecting the Machine to a Computer or Network," "Interface Settings," and "Communication Environment Setup," specify a TCP/IP or SMB/CIFS network, depending on the protocol.
Sample Macintosh Network
In Mac OS 8/9, the AppleTalk (EtherTalk) protocol is used. In Mac OS X, either the AppleTalk (EtherTalk), TCP/IP, or NetBIOS (NetBIOS over TCP/IP) protocol can be used. To use the e-mail/I-fax function or to send data, the TCP/IP protocol is required.
After configuring the settings in accordance with "Connecting the Machine to a Computer or Network," "Interface Settings," and "Communication Environment Setup," specify an AppleTalk (Macintosh), TCP/IP, or SMB/CIFS network, depending on the protocol.
Sample UNIX Network
With UNIX computers, the TCP/IP protocol is used.
After configuring the settings in accordance with "Connecting the Machine to a Computer or Network," "Interface Settings," and "Communication Environment Setup," set a TCP/IP network.
Using a Network with Various Types of Computers
If there are various types of computers on the network, the network operations you are required to perform depend on the type of computers being used.
For example, if you are using both Windows XP and Macintosh computers, you will need to specify the settings described in both "Sample Windows Network" and "Sample Macintosh Network."
To use the data sending function, either the TCP/IP or NetBIOS protocol is required.
After configuring the settings in accordance with "Connecting the Machine to a Computer or Network," "Interface Settings," and "Communication Environment Setup," specify a TCP/IP, NetWare, SMB/CIFS, or AppleTalk (Macintosh) network, depending on the protocol.
If you are using the imagePASS, see the manual provided with the imagePASS.
If you are using the imagePASS, some functions are not available with this machine. For details, see the manual provided with the imagePASS.
The machine does not support NetBEUI.
The protocol you can use differs depending on the version of Mac OS or type of printer driver. For more information, see "Printing from a Computer (Mac)."
When [Sleep Mode Energy Use] is set to [Low] and the machine is in the Sleep mode, communication failure may occur, depending on the utility software you are using. To avoid this, press (Energy Saver) to cancel the Sleep mode before specifying the setting, or set [Sleep Mode Energy Use] to [High]. (See "Energy Consumption in the Sleep Mode.")
