Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows 2000/XP/Server 2003/Server 2008/Vista/7/Server 2008 R2
Mac OS X 10.3.9 or Later
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2
Top » Network » Optional Equipment and System Requirements » Sending Data
Sending Data
08KE-1RX
Optional Equipment Requirements
Optional equipment is not required for sending data.
System Requirements
The following network and system environments are compatible when sending data from the machine to a file server, depending on the type of network used:
With a TCP/IPv4 Network (Using FTP):
Compatible Servers
Windows XP Professional and Internet Information Services (IIS) 5.1
Windows Server 2003 and IIS 6.0
Windows Server 2008 and IIS 7.0
Windows Vista Ultimate and IIS 7.0
Windows Vista Business and IIS 7.0
Windows Vista Home Premium and IIS 7.0
Windows Vista Home Basic and IIS 7.0
Windows Vista Enterprise and IIS 7.0
Windows 7 Ultimate and IIS 7.5
Windows 7 Enterprise and IIS 7.5
Windows 7 Professional and IIS 7.5
Windows 7 Home Premium and IIS 7.5
Windows Server 2008 R2 and IIS 7.5
Solaris Version 2.6 or later
Red Hat Linux 7.2 or later
Mac OS X 10.4.x/10.5.x/10.6.x
Compatible Protocol
TCP/IPv4
With a TCP/IPv6 Network (Using FTP):
Compatible Servers
Solaris Version 9 or later
Red Hat Enterprise Linux AS/ES/WS 4.0 or later
Compatible Protocol
TCP/IPv6
With a TCP/IPv4 Network (Using WebDAV):
Compatible Servers
Windows XP Professional and IIS 5.1
Windows XP Professional and Apache 2.0 for Win 32
Windows Server 2003 and Apache 2.0 for Win 32
Windows Server 2008 and Apache 2.0 or later
Windows Vista Ultimate and Apache 2.0 or later
Windows Vista Business and Apache 2.0 or later
Windows Vista Home Premium and Apache 2.0 or later
Windows Vista Home Basic and Apache 2.0 or later
Windows Vista Enterprise and Apache 2.0 or later
Windows 7 Ultimate and Apache 2.0 or later
Windows 7 Enterprise and Apache 2.0 or later
Windows 7 Professional and Apache 2.0 or later
Windows 7 Home Premium and Apache 2.0 or later
Windows Server 2008 R2 and Apache 2.0 or later
Solaris Version 2.6 or later, and Apache 2.0 or later
Red Hat Enterprise Linux AS/ES/WS 4.0 or later, and Apache 2.0 or later
Compatible protocol for the WebDAV server
TCP/IPv4
With a TCP/IPv6 Network (Using WebDAV):
Compatible Servers
TCP/IPv6
With an SMB/CIFS Network:
Compatible Servers
Windows XP Home Edition
Windows Server 2003
Windows Server 2008
Windows 7 Ultimate
Compatible server software for sending data
Samba 2.2.8a or later (UNIX/Linux/Mac OS X 10.4.x/10.5.x/10.6.x)
Compatible Protocol
NetBIOS over TCP/IP (NetBT)
If you are using the imagePASS, see the manual provided with the imagePASS.
If you are using the imagePASS, some functions are not available with this machine. For details, see the manual provided with the imagePASS.
If you connect to the internet via a proxy, the proxy server must support IPv6.
